[Liblas-commits] laszip: switching on LASzip v2.0 with chunking
liblas-commits at liblas.org
Thu Jun 23 18:46:20 EDT 2011
details: http://hg.liblas.orglaszip/rev/3a95147cf872
changeset: 254:3a95147cf872
user: isenburg
date: Thu Jun 23 15:43:36 2011 -0700
description:
Subject: laszip: formulation
details: http://hg.liblas.orglaszip/rev/82caca9b9a7b
changeset: 255:82caca9b9a7b
user: isenburg
date: Thu Jun 23 15:45:21 2011 -0700
description:
formulation
Subject: laszip: merge
details: http://hg.liblas.orglaszip/rev/ee32a166b79c
changeset: 256:ee32a166b79c
user: isenburg
date: Thu Jun 23 15:46:15 2011 -0700
description:
merge
Subject: laszip: switching on LASzip v2.0 with chunking
details: http://hg.liblas.orglaszip/rev/4f8b0216c71b
changeset: 257:4f8b0216c71b
user: isenburg
date: Thu Jun 23 15:48:07 2011 -0700
description:
Subject: laszip: updates test
details: http://hg.liblas.orglaszip/rev/a5b6753ac08d
changeset: 258:a5b6753ac08d
user: isenburg
date: Thu Jun 23 15:48:49 2011 -0700
description:
updates test
diffstat:
.hgtags | 1 +
CMakeLists.txt | 6 +++---
HOWTORELEASE.txt | 13 +++++++++----
configure.ac | 4 ++--
docs/source/index.rst | 12 ++++++------
include/laszip/laszip.hpp | 45 ++++++++++++++++++++++++---------------------
src/laszip.cpp | 33 +++++++++++++++------------------
tools/laszippertest.cpp | 10 +++++-----
8 files changed, 65 insertions(+), 59 deletions(-)
diffs (truncated from 347 to 300 lines):
diff -r 0bf6c8e259d1 -r a5b6753ac08d .hgtags
--- a/.hgtags Wed Jun 22 09:13:09 2011 -0700
+++ b/.hgtags Thu Jun 23 15:48:49 2011 -0700
@@ -1,2 +1,3 @@
a216ab3ddb11e21d0db830e2f68f6a20cc64d3e0 1.0.1
8144ee77b7704e0fe45a75fa33c777bb45335ffb 1.2.0
+037abfa227a0e8f16d3100f5d01ed91e16247b19 2.0.0
diff -r 0bf6c8e259d1 -r a5b6753ac08d CMakeLists.txt
--- a/CMakeLists.txt Wed Jun 22 09:13:09 2011 -0700
+++ b/CMakeLists.txt Thu Jun 23 15:48:49 2011 -0700
@@ -9,11 +9,11 @@
project(laszip)
-SET(LASZIP_VERSION_MAJOR "1")
-SET(LASZIP_VERSION_MINOR "2")
+SET(LASZIP_VERSION_MAJOR "2")
+SET(LASZIP_VERSION_MINOR "0")
SET(LASZIP_VERSION_PATCH "0")
set(VERSION "${LASZIP_VERSION_MAJOR}.${LASZIP_VERSION_MINOR}.${LASZIP_VERSION_PATCH}")
-SET(LASZIP_LIB_SOVERSION "3.0.1")
+SET(LASZIP_LIB_SOVERSION "4.0.1")
# Name of C++ library
set(LASZIP_LIB_NAME laszip)
diff -r 0bf6c8e259d1 -r a5b6753ac08d HOWTORELEASE.txt
--- a/HOWTORELEASE.txt Wed Jun 22 09:13:09 2011 -0700
+++ b/HOWTORELEASE.txt Thu Jun 23 15:48:49 2011 -0700
@@ -19,16 +19,21 @@
- CMakeLists.txt
- * SET(LASZIP_VERSION_MAJOR "1")
+ * SET(LASZIP_VERSION_MAJOR "2")
* SET(LASZIP_VERSION_MINOR "0")
- * SET(LASZIP_VERSION_PATCH "0b1")
+ * SET(LASZIP_VERSION_PATCH "0")
- include/laszip/laszip.hpp
- * #define LASZIP_VERSION_MAJOR 1
+ * #define LASZIP_VERSION_MAJOR 2
* #define LASZIP_VERSION_MINOR 0
- * #define LASZIP_VERSION_REV 0b1
+ * #define LASZIP_VERSION_REV 0
+ - configure.ac
+ * m4_define([laszip_version_major], [2])
+ * m4_define([laszip_version_minor], [0])
+ * m4_define([laszip_version_micro], [0])
2) Update README to include any relevant info about the release that
diff -r 0bf6c8e259d1 -r a5b6753ac08d configure.ac
--- a/configure.ac Wed Jun 22 09:13:09 2011 -0700
+++ b/configure.ac Thu Jun 23 15:48:49 2011 -0700
@@ -2,9 +2,9 @@
dnl
dnl This is main autoconf bootstrap script of libLAS project.
dnl
-m4_define([laszip_version_major], [1])
+m4_define([laszip_version_major], [2])
-m4_define([laszip_version_micro], [b1])
+m4_define([laszip_version_micro], [0])
m4_define([laszip_version],
[laszip_version_major.laszip_version_minor.laszip_version_micro])
diff -r 0bf6c8e259d1 -r a5b6753ac08d docs/source/index.rst
--- a/docs/source/index.rst Wed Jun 22 09:13:09 2011 -0700
+++ b/docs/source/index.rst Thu Jun 23 15:48:49 2011 -0700
@@ -14,13 +14,13 @@
Source
-* **2011-04-05**
+* **2011-06-23**
- - `laszip-1.2.0-src.tar.gz <http://download.osgeo.org/laszip/laszip-1.2.0.tar.gz>`_
- `(md5) <http://download.osgeo.org/laszip/laszip-1.2.0.tar.gz.md5>`__
+ - `laszip-2.0.0-src.tar.gz <http://download.osgeo.org/laszip/laszip-2.0.0.tar.gz>`_
+ `(md5) <http://download.osgeo.org/laszip/laszip-2.0.0.tar.gz.md5>`__
- - `laszip-1.2.0-src.zip <http://download.osgeo.org/laszip/laszip-1.2.0.zip>`_
- `(md5) <http://download.osgeo.org/liblas/laszip-1.2.0.zip.md5>`__
+ - `laszip-2.0.0-src.zip <http://download.osgeo.org/laszip/laszip-2.0.0.zip>`_
+ `(md5) <http://download.osgeo.org/liblas/laszip-2.0.0.zip.md5>`__
Binaries
@@ -29,7 +29,7 @@
include files to compile LASzip into your own application. `libLAS`_
binaries through `OSGeo4W`_ also link LASzip.
- - A Windows binary `laszip.exe`_ and a simple makefile to build `laszip`_ are
+ - A Windows binary `laszip.exe`_ and a Linux makefile to build `laszip`_ are
available for explicit compression (decompression) of LAS (LAZ) files.
diff -r 0bf6c8e259d1 -r a5b6753ac08d include/laszip/laszip.hpp
--- a/include/laszip/laszip.hpp Wed Jun 22 09:13:09 2011 -0700
+++ b/include/laszip/laszip.hpp Thu Jun 23 15:48:49 2011 -0700
@@ -1,13 +1,13 @@
- FILE: laszip.hpp
- CONTENTS:
+ FILE: laszip.hpp
+ CONTENTS:
Contains LASitem and LASchunk structs as well as the IDs of the currently
- supported entropy coding scheme
+ supported entropy coding scheme
PROGRAMMERS:
martin.isenburg at gmail.com
@@ -25,16 +25,17 @@
CHANGE HISTORY:
+ 23 June 2011 -- turned on LASzip version 2.0 compressor with chunking
8 May 2011 -- added an option for variable chunking via chunk()
23 April 2011 -- changed interface for simplicity and chunking support
20 March 2011 -- incrementing LASZIP_VERSION to 1.2 for improved compression
10 January 2011 -- licensing change for LGPL release and liblas integration
12 December 2010 -- refactored from lasdefinitions after movies with silke
-#ifndef LASZIP_HPP
-#define LASZIP_HPP
+#ifndef LASZIP_HPP
+#define LASZIP_HPP
#if defined(_MSC_VER) && (_MSC_VER < 1300)
#define LZ_WIN32_VC6
@@ -43,8 +44,8 @@
typedef long long SIGNED_INT64;
#endif
-#define LASZIP_VERSION_MAJOR 1
-#define LASZIP_VERSION_MINOR 2
+#define LASZIP_VERSION_MAJOR 2
+#define LASZIP_VERSION_MINOR 0
#define LASZIP_VERSION_REVISION 0
#define LASZIP_COMPRESSOR_NONE 0
@@ -52,8 +53,10 @@
#define LASZIP_COMPRESSOR_POINTWISE_CHUNKED 2
#define LASZIP_COMPRESSOR_TOTAL_NUMBER_OF 3
-#define LASZIP_COMPRESSOR_DEFAULT LASZIP_COMPRESSOR_POINTWISE
#define LASZIP_COMPRESSOR_CHUNKED LASZIP_COMPRESSOR_POINTWISE_CHUNKED
+#define LASZIP_COMPRESSOR_NOT_CHUNKED LASZIP_COMPRESSOR_POINTWISE
+#define LASZIP_COMPRESSOR_DEFAULT LASZIP_COMPRESSOR_CHUNKED
#define LASZIP_CODER_ARITHMETIC 0
#define LASZIP_CODER_TOTAL_NUMBER_OF 1
@@ -85,8 +88,8 @@
// go back and forth between item array and point type & size
bool setup(unsigned short* num_items, LASitem** items, const unsigned char point_type, const unsigned short point_size, const unsigned short compressor=LASZIP_COMPRESSOR_NONE);
- bool is_standard(const unsigned short num_items, const LASitem* items, unsigned char* point_type=0, unsigned short* record_length=0) const;
- bool is_standard(unsigned char* point_type=0, unsigned short* record_length=0) const;
+ bool is_standard(const unsigned short num_items, const LASitem* items, unsigned char* point_type=0, unsigned short* record_length=0);
+ bool is_standard(unsigned char* point_type=0, unsigned short* record_length=0);
// pack to and unpack from VLR
unsigned char* bytes;
@@ -95,7 +98,7 @@
// setup
bool setup(const unsigned char point_type, const unsigned short point_size, const unsigned short compressor=LASZIP_COMPRESSOR_DEFAULT);
- bool setup(const unsigned short num_items, const LASitem* items, const unsigned short compressor=LASZIP_COMPRESSOR_DEFAULT);
+ bool setup(const unsigned short num_items, const LASitem* items, const unsigned short compressor);
bool set_chunk_size(const unsigned int chunk_size); /* for compressor only */
bool request_version(const unsigned short requested_version); /* for compressor only */
@@ -123,4 +126,4 @@
char* error_string;
-#endif
+#endif
diff -r 0bf6c8e259d1 -r a5b6753ac08d src/laszip.cpp
--- a/src/laszip.cpp Wed Jun 22 09:13:09 2011 -0700
+++ b/src/laszip.cpp Thu Jun 23 15:48:49 2011 -0700
@@ -45,7 +45,7 @@
version_revision = LASZIP_VERSION_REVISION;
options = 0;
num_items = 0;
- chunk_size = 0;
+ chunk_size = LASZIP_CHUNK_SIZE_DEFAULT;
num_points = -1;
num_bytes = -1;
error_string = 0;
@@ -362,10 +362,6 @@
return return_error(error);
- // choose version
- U16 version = 0;
- if (compressor) version = 1;
// create item description
(*num_items) = 1 + !!(have_gps_time) + !!(have_rgb) + !!(have_wavepacket) + !!(extra_bytes_number);
@@ -374,35 +370,36 @@
U16 i = 1;
(*items)[0].type = LASitem::POINT10;
(*items)[0].size = 20;
- (*items)[0].version = version;
+ (*items)[0].version = 0;
if (have_gps_time)
(*items)[i].type = LASitem::GPSTIME11;
(*items)[i].size = 8;
- (*items)[i].version = version;
+ (*items)[i].version = 0;
i++;
if (have_rgb)
(*items)[i].type = LASitem::RGB12;
(*items)[i].size = 6;
i++;
if (have_wavepacket)
(*items)[i].type = LASitem::WAVEPACKET13;
(*items)[i].size = 29;
i++;
if (extra_bytes_number)
(*items)[i].type = LASitem::BYTE;
(*items)[i].size = extra_bytes_number;
i++;
+ if (compressor) request_version(2);
assert(i == *num_items);
return true;
@@ -445,20 +442,20 @@
items[i].version = 1; // no version 2
break;
default:
- return false;
+ return return_error("itrm type not supported");
return true;
-bool LASzip::is_standard(U8* point_type, U16* record_length) const
+bool LASzip::is_standard(U8* point_type, U16* record_length)
return is_standard(num_items, items, point_type, record_length);
-bool LASzip::is_standard(const U16 num_items, const LASitem* items, U8* point_type, U16* record_length) const
+bool LASzip::is_standard(const U16 num_items, const LASitem* items, U8* point_type, U16* record_length)
- if (items == 0) return false;
+ if (items == 0) return return_error("LASitem array is zero");
// this is always true
if (point_type) *point_type = 127;
@@ -473,12 +470,12 @@
// the minimal number of items is 1
- if (num_items < 1) return false;
+ if (num_items < 1) return return_error("less than one LASitem entries");
// the maximal number of items is 5
- if (num_items > 5) return false;
+ if (num_items > 5) return return_error("more than five LASitem entries");
// all standard point types start with POINT10
- if (!items[0].is_type(LASitem::POINT10)) return false;
More information about the Liblas-commits
