[Liblas-commits] hg: Use the m_zipPoint's LASzip instead of one on
	the reader
    liblas-commits at liblas.org
    Mon Jun 27 15:59:03 EDT 2011
details:   http://hg.liblas.orghg/rev/b76368277444
changeset: 3025:b76368277444
user:      Howard Butler <hobu.inc at gmail.com>
date:      Mon Jun 27 14:58:36 2011 -0500
description:
Use the m_zipPoint's LASzip instead of one on the reader
Subject: hg: merge
details:   http://hg.liblas.orghg/rev/311ca9ff9d99
changeset: 3026:311ca9ff9d99
date:      Mon Jun 27 14:58:58 2011 -0500
description:
merge
diffstat:
 include/liblas/detail/reader/zipreader.hpp |   2 +-
 mpg-config.bat                             |   2 +-
 src/detail/reader/zipreader.cpp            |  18 ++++++------------
 3 files changed, 8 insertions(+), 14 deletions(-)
diffs (83 lines):
diff -r a95fbeb13499 -r 311ca9ff9d99 include/liblas/detail/reader/zipreader.hpp
--- a/include/liblas/detail/reader/zipreader.hpp	Mon Jun 27 12:19:12 2011 -0700
+++ b/include/liblas/detail/reader/zipreader.hpp	Mon Jun 27 14:58:58 2011 -0500
@@ -112,7 +112,7 @@
 private:
     void ReadIdiom();
-    boost::scoped_ptr<LASzip> m_zip;
+    // boost::scoped_ptr<LASzip> m_zip;
     boost::scoped_ptr<ZipPoint> m_zipPoint;
     boost::scoped_ptr<LASunzipper> m_unzipper;
diff -r a95fbeb13499 -r 311ca9ff9d99 mpg-config.bat
--- a/mpg-config.bat	Mon Jun 27 12:19:12 2011 -0700
+++ b/mpg-config.bat	Mon Jun 27 14:58:58 2011 -0500
@@ -12,7 +12,7 @@
 set LIBLAS=%DEV_DIR%\liblas
 set LASZIP=%DEV_DIR%\laszip
-set BOOST=%UTILS_DIR%\boost_1_46_1
+set BOOST=%UTILS_DIR%\boost_pro_1_46_1
 cmake -G %COMPILER% ^
     -DBOOST_INCLUDEDIR=%BOOST% ^
diff -r a95fbeb13499 -r 311ca9ff9d99 src/detail/reader/zipreader.cpp
--- a/src/detail/reader/zipreader.cpp	Mon Jun 27 12:19:12 2011 -0700
+++ b/src/detail/reader/zipreader.cpp	Mon Jun 27 14:58:58 2011 -0500
@@ -85,7 +85,6 @@
     m_zipPoint.reset();
-    m_zip.reset();
     m_unzipper.reset();
     return;
@@ -103,33 +102,28 @@
     // If we reset the reader, we're ready to start reading points, so
     // we'll create a point reader at this point.
-    if (!m_zip)
+    if (!m_zipPoint)
-        // Initialize a scoped_ptr and swap it with our member variable
-        // that will contain it.
-        boost::scoped_ptr<LASzip> s(new LASzip());
-        m_zip.swap(s);
         PointFormatName format = m_header->GetDataFormatId();
         boost::scoped_ptr<ZipPoint> z(new ZipPoint(format, m_header->GetVLRs()));
         m_zipPoint.swap(z);
         bool ok = false;
-        ok = m_zip->setup((unsigned char)format, m_header->GetDataRecordLength());
+        ok = m_zipPoint->GetZipper()->setup((unsigned char)format, m_header->GetDataRecordLength());
         if (!ok)
             std::ostringstream oss;
-            oss << "Error setting up compression engine: " << std::string(m_zip->get_error());
+            oss << "Error setting up compression engine: " << std::string(m_zipPoint->GetZipper()->get_error());
             throw liblas_error(oss.str());
-        ok = m_zip->unpack(m_zipPoint->our_vlr_data.get(), m_zipPoint->our_vlr_num);
+        ok = m_zipPoint->GetZipper()->unpack(m_zipPoint->our_vlr_data.get(), m_zipPoint->our_vlr_num);
         if (!ok)
-            oss << "Error unpacking zip VLR data: " << std::string(m_zip->get_error());
+            oss << "Error unpacking zip VLR data: " << std::string(m_zipPoint->GetZipper()->get_error());
@@ -141,7 +135,7 @@
         bool stat(false);
         m_ifs.seekg(m_header->GetDataOffset(), std::ios::beg);
-        stat = m_unzipper->open(m_ifs, m_zip.get());
+        stat = m_unzipper->open(m_ifs, m_zipPoint->GetZipper());
         if (!stat)
More information about the Liblas-commits
