[Liblas-commits] libpc: get swig building
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Mar 3 13:09:33 EST 2011
details:   http://hg.liblas.orglibpc/rev/c2bebf3e40bd
changeset: 160:c2bebf3e40bd
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Thu Mar 03 09:55:47 2011 -0800
description:
get swig building
Subject: libpc: get swig building
details:   http://hg.liblas.orglibpc/rev/fd1e3abfca1d
changeset: 161:fd1e3abfca1d
date:      Thu Mar 03 09:58:37 2011 -0800
description:
get swig building
Subject: libpc: start of pcview
details:   http://hg.liblas.orglibpc/rev/598d3126a001
changeset: 162:598d3126a001
date:      Thu Mar 03 10:09:26 2011 -0800
description:
start of pcview
diffstat:
 .hgignore                                     |     4 +
 csharp/PCView/App.xaml                        |     8 +
 csharp/PCView/App.xaml.cs                     |    44 +
 csharp/PCView/Mouse.fx                        |    35 +
 csharp/PCView/Mouse.xaml                      |    14 +
 csharp/PCView/Mouse.xaml.cs                   |   205 ++
 csharp/PCView/MouseRenderEngine.cs            |   296 ++++
 csharp/PCView/PCView.csproj                   |   141 ++
 csharp/PCView/Properties/AssemblyInfo.cs      |    58 +
 csharp/PCView/app.config                      |     3 +
 csharp/README.txt                             |     4 +
 csharp/libpc_swig.sln                         |   127 +-
 csharp/libpc_swig_cpp/libpc.i                 |   162 +-
 csharp/libpc_swig_cpp/libpc_swig_cpp.vcxproj  |   356 ++--
 csharp/libpc_swig_cpp/libpc_wrap.cpp          |  1722 -------------------------
 csharp/libpc_swig_cs/Dimension.cs             |   179 --
 csharp/libpc_swig_cs/VectorU32.cs             |   349 -----
 csharp/libpc_swig_cs/VectorU8.cs              |   349 -----
 csharp/libpc_swig_cs/libpc_swig_cpp.cs        |    17 -
 csharp/libpc_swig_cs/libpc_swig_cppPINVOKE.cs |   427 ------
 csharp/libpc_swig_cs/libpc_swig_cs.csproj     |   208 +-
 csharp/libpc_swig_test/Program.cs             |    76 +-
 csharp/libpc_swig_test/TestDimension.cs       |    56 +-
 csharp/libpc_swig_test/libpc_swig_test.csproj |   190 +-
 mpg-config.bat                                |     6 +-
 25 files changed, 1422 insertions(+), 3614 deletions(-)
diffs (truncated from 5194 to 300 lines):
diff -r 689b6280c0d2 -r 598d3126a001 .hgignore
--- a/.hgignore	Wed Mar 02 20:47:18 2011 -0800
+++ b/.hgignore	Thu Mar 03 10:09:26 2011 -0800
@@ -1,5 +1,6 @@
 syntax: glob
+# this is generated by cmake
 libpc_defines.h
 # rst outputs
@@ -27,3 +28,6 @@
 *.sdf
 *.suo
 *.opensdf
+# generated swig files
+csharp/libpc_swig_cs/*.cs
diff -r 689b6280c0d2 -r 598d3126a001 csharp/PCView/App.xaml
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/csharp/PCView/App.xaml	Thu Mar 03 10:09:26 2011 -0800
@@ -0,0 +1,8 @@
+<Application x:Class="Flaxen.SlimDXControlLib.MouseExample.MouseApp"
+             xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
+             xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
+             StartupUri="Mouse.xaml">
+    <Application.Resources>
+    </Application.Resources>
+</Application>
diff -r 689b6280c0d2 -r 598d3126a001 csharp/PCView/App.xaml.cs
+++ b/csharp/PCView/App.xaml.cs	Thu Mar 03 10:09:26 2011 -0800
@@ -0,0 +1,44 @@
+// <copyright file="App.xaml.cs" company="Flaxen Geo">
+//    Copyright (c) 2011, Michael P. Gerlek.  All rights reserved.
+// </copyright>
+// Redistribution and use in source and binary forms, with or without
+// modification, are permitted provided that the following conditions are
+// met:
+// * Redistributions of source code must retain the above copyright notice,
+//   this list of conditions and the following disclaimer.
+// * Redistributions in binary form must reproduce the above copyright notice,
+//   this list of conditions and the following disclaimer in the documentation
+//   and/or other materials provided with the distribution.
+// * Neither the name of Flaxen Geo nor the names of its contributors may be
+//   used to endorse or promote products derived from this software without
+//   specific prior written permission.
+// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+// AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+// IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+// ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+// LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+// CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+// SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+// INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+// CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+// ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
+// THE POSSIBILITY OF SUCH DAMAGE.
+namespace Flaxen.SlimDXControlLib.MouseExample
+    using System.Windows;
+    /// <summary>
+    /// App class for the Mouse example.
+    /// </summary>
+    public partial class MouseApp : Application
diff -r 689b6280c0d2 -r 598d3126a001 csharp/PCView/Mouse.fx
+++ b/csharp/PCView/Mouse.fx	Thu Mar 03 10:09:26 2011 -0800
@@ -0,0 +1,35 @@
+cbuffer cbPerObject
+    float4x4 gWVP;
+// VertexShader
+void VS(float4 inputPos: POSITION,
+        float4 inputCol: COLOR,
+        out float4 outputPos : SV_POSITION,
+        out float4 outputCol : COLOR)
+    //PS_IN output = (PS_IN)0;
+    outputPos = mul(inputPos, gWVP);
+    outputCol = inputCol;
+// PixelShader
+void PS(float4 inputPos: SV_POSITION,
+        out float4 outputCol: SV_TARGET)
+technique10 Render
+    pass P0
+        SetGeometryShader( 0 );
+        SetVertexShader( CompileShader( vs_4_0, VS() ) );
+        SetPixelShader( CompileShader( ps_4_0, PS() ) );
diff -r 689b6280c0d2 -r 598d3126a001 csharp/PCView/Mouse.xaml
+++ b/csharp/PCView/Mouse.xaml	Thu Mar 03 10:09:26 2011 -0800
@@ -0,0 +1,14 @@
+<Window x:Class="Flaxen.SlimDXControlLib.MouseExample.Mouse"
+    xmlns:d3d="clr-namespace:Flaxen.SlimDXControlLib;assembly=Flaxen.SlimDXControlLib"
+    Title="Mouse Example"
+    Width="500"
+    Height="500">
+    <DockPanel LastChildFill="True" >
+        <TextBlock DockPanel.Dock="Bottom" Text="{Binding Path=PositionString}" />
+        <d3d:SlimDXControl DockPanel.Dock="Top" x:Name="x_contentControl" />
+    </DockPanel>
+</Window>
diff -r 689b6280c0d2 -r 598d3126a001 csharp/PCView/Mouse.xaml.cs
+++ b/csharp/PCView/Mouse.xaml.cs	Thu Mar 03 10:09:26 2011 -0800
@@ -0,0 +1,205 @@
+// <copyright file="Mouse.xaml.cs" company="Flaxen Geo">
+// </copyright>
+// met:
+    using System.Collections.Generic;
+    using System.ComponentModel;
+    using System.Globalization;
+    using System.Windows.Documents;
+    using System.Windows.Input;
+    using SlimDX;
+    /// <summary>
+    /// Implements the MouseExample test.
+    /// </summary>
+    public partial class Mouse : Window, INotifyPropertyChanged
+        private MouseRenderEngine m_renderEngine;
+        private Point m_downPoint;
+        private bool m_isMoving = false;
+        private string m_positionString;
+        /// <summary>
+        /// Initializes a new instance of the Mouse class.
+        /// </summary>
+        public Mouse()
+            InitializeComponent();
+            Vector4[] points = CreateAxes();
+            m_renderEngine = new MouseRenderEngine(points);
+            x_contentControl.RegisterRenderer(m_renderEngine);
+            this.MouseMove += new MouseEventHandler(Mouse_MouseMove);
+            this.MouseDown += new MouseButtonEventHandler(Mouse_MouseDown);
+            this.MouseUp += new MouseButtonEventHandler(Mouse_MouseUp);
+            this.MouseWheel += new MouseWheelEventHandler(Mouse_MouseWheel);
+            PositionString = string.Empty;
+            this.DataContext = this;
+            return;
+        /// <summary>
+        /// Gets or sets a string containing the mouse position (in world coordinates).
+        /// </summary>
+        public string PositionString
+            get
+                return m_positionString;
+            set
+                if (value != m_positionString)
+                    m_positionString = value;
+                    NotifyPropertyChanged("PositionString");
+        #region mouse handlers
+        private void Mouse_MouseDown(object sender, MouseButtonEventArgs e)
+            if (e.LeftButton == MouseButtonState.Pressed)
+                m_downPoint = e.GetPosition(x_contentControl);
+                m_isMoving = true;
+        private void Mouse_MouseUp(object sender, MouseButtonEventArgs e)
+            m_isMoving = false;
+        private void Mouse_MouseMove(object sender, MouseEventArgs e)
+            Point mouse = e.GetPosition(x_contentControl);
+            Vector3 world = m_renderEngine.ConvertToWorldCoordinates(mouse, (float)x_contentControl.ActualWidth, (float)x_contentControl.ActualHeight);
+            PositionString = string.Format(
+                CultureInfo.InvariantCulture,
+                "[{0},{1}]  X={2}  Y={3}  Z={4}",
+                mouse.X,
+                mouse.Y,
+                world.X.ToString("F1", CultureInfo.InvariantCulture),
+                world.Y.ToString("F1", CultureInfo.InvariantCulture),
+                world.Z.ToString("F1", CultureInfo.InvariantCulture));
+                if (m_isMoving)
+                    Point currPoint = e.GetPosition(x_contentControl);
+                    Vector3 camera = m_renderEngine.CameraPosition;
+                    Vector3 target = m_renderEngine.TargetPosition;
+                    camera.X += (float)(m_downPoint.X - currPoint.X) / 100.0f;
+                    target.X += (float)(m_downPoint.X - currPoint.X) / 100.0f;
+                    camera.Y += -(float)(m_downPoint.Y - currPoint.Y) / 100.0f;
+                    target.Y += -(float)(m_downPoint.Y - currPoint.Y) / 100.0f;
+                    m_renderEngine.CameraPosition = camera;
+                    m_renderEngine.TargetPosition = target;
+                    m_downPoint = currPoint;
+            return;
+        private void Mouse_MouseWheel(object sender, MouseWheelEventArgs e)
+            camera.Z += e.Delta / 100.0f;
+        #endregion
+        private Vector4[] CreateAxes()
+            Vector4 red = new Vector4(1, 0, 0, 1);
+            Vector4 green = new Vector4(0, 1, 0, 1);
+            Vector4 blue = new Vector4(0, 0, 1, 1);
+            List<Vector4> points = new List<Vector4>();
More information about the Liblas-commits mailing list
