[Liblas-commits] libpc: pcview work
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Mar 4 17:47:45 EST 2011
details:   http://hg.liblas.orglibpc/rev/23e91f43b490
changeset: 178:23e91f43b490
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Fri Mar 04 14:47:27 2011 -0800
description:
pcview work
diffstat:
 csharp/PCView/App.xaml                  |    2 +-
 csharp/PCView/MainWindow.xaml           |   14 +
 csharp/PCView/MainWindow.xaml.cs        |  196 ++++++++++++
 csharp/PCView/Mouse.fx                  |   35 --
 csharp/PCView/Mouse.xaml                |   14 -
 csharp/PCView/Mouse.xaml.cs             |  205 -------------
 csharp/PCView/MouseRenderEngine.cs      |  296 -------------------
 csharp/PCView/PCView.csproj             |   10 +-
 csharp/PCView/PointCloudRenderEngine.cs |  493 ++++++++++++++++++++++++++++++++
 csharp/PCView/pipeline.fx               |   35 ++
 10 files changed, 744 insertions(+), 556 deletions(-)
diffs (truncated from 1366 to 300 lines):
diff -r d0ca3d54fcdb -r 23e91f43b490 csharp/PCView/App.xaml
--- a/csharp/PCView/App.xaml	Fri Mar 04 12:39:35 2011 -0800
+++ b/csharp/PCView/App.xaml	Fri Mar 04 14:47:27 2011 -0800
@@ -1,7 +1,7 @@
 <Application x:Class="Flaxen.SlimDXControlLib.MouseExample.MouseApp"
              xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
              xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
-             StartupUri="Mouse.xaml">
+             StartupUri="MainWindow.xaml">
     <Application.Resources>
     </Application.Resources>
diff -r d0ca3d54fcdb -r 23e91f43b490 csharp/PCView/MainWindow.xaml
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/csharp/PCView/MainWindow.xaml	Fri Mar 04 14:47:27 2011 -0800
@@ -0,0 +1,14 @@
+<Window x:Class="Flaxen.SlimDXControlLib.MouseExample.MainWindow"
+    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
+    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
+    xmlns:d3d="clr-namespace:Flaxen.SlimDXControlLib;assembly=Flaxen.SlimDXControlLib"
+    Title="Mouse Example"
+    Width="500"
+    Height="500">
+    <DockPanel LastChildFill="True" >
+        <TextBlock DockPanel.Dock="Bottom" Text="{Binding Path=PositionString}" />
+        <d3d:SlimDXControl DockPanel.Dock="Top" x:Name="x_contentControl" />
+    </DockPanel>
+</Window>
diff -r d0ca3d54fcdb -r 23e91f43b490 csharp/PCView/MainWindow.xaml.cs
+++ b/csharp/PCView/MainWindow.xaml.cs	Fri Mar 04 14:47:27 2011 -0800
@@ -0,0 +1,196 @@
+// <copyright file="Mouse.xaml.cs" company="Flaxen Geo">
+//    Copyright (c) 2011, Michael P. Gerlek.  All rights reserved.
+// </copyright>
+// Redistribution and use in source and binary forms, with or without
+// modification, are permitted provided that the following conditions are
+// met:
+// * Redistributions of source code must retain the above copyright notice,
+//   this list of conditions and the following disclaimer.
+// * Redistributions in binary form must reproduce the above copyright notice,
+//   this list of conditions and the following disclaimer in the documentation
+//   and/or other materials provided with the distribution.
+// * Neither the name of Flaxen Geo nor the names of its contributors may be
+//   used to endorse or promote products derived from this software without
+//   specific prior written permission.
+// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+// AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+// IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+// ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+// LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+// CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+// SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+// INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+// CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+// ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
+// THE POSSIBILITY OF SUCH DAMAGE.
+namespace Flaxen.SlimDXControlLib.MouseExample
+    using System.Collections.Generic;
+    using System.ComponentModel;
+    using System.Globalization;
+    using System.Windows;
+    using System.Windows.Documents;
+    using System.Windows.Input;
+    using SlimDX;
+    /// <summary>
+    /// Implements the MouseExample test.
+    /// </summary>
+    public partial class MainWindow : Window, INotifyPropertyChanged
+        private PointCloudRenderEngine m_renderEngine;
+        private Point m_downPoint;
+        private bool m_isMoving = false;
+        private string m_positionString;
+        /// <summary>
+        /// Initializes a new instance of the Mouse class.
+        /// </summary>
+        public MainWindow()
+            InitializeComponent();
+            m_renderEngine = new PointCloudRenderEngine();
+            x_contentControl.RegisterRenderer(m_renderEngine);
+            this.MouseMove += new MouseEventHandler(Mouse_MouseMove);
+            this.MouseDown += new MouseButtonEventHandler(Mouse_MouseDown);
+            this.MouseUp += new MouseButtonEventHandler(Mouse_MouseUp);
+            this.MouseWheel += new MouseWheelEventHandler(Mouse_MouseWheel);
+            PositionString = string.Empty;
+            this.DataContext = this;
+            Vector4[] points = CreateData();
+            m_renderEngine.SetPoints(points);
+            return;
+        /// <summary>
+        /// Gets or sets a string containing the mouse position (in world coordinates).
+        /// </summary>
+        public string PositionString
+            get
+                return m_positionString;
+            set
+                if (value != m_positionString)
+                    m_positionString = value;
+                    NotifyPropertyChanged("PositionString");
+        #region mouse handlers
+        private void Mouse_MouseDown(object sender, MouseButtonEventArgs e)
+            if (e.LeftButton == MouseButtonState.Pressed)
+                m_downPoint = e.GetPosition(x_contentControl);
+                m_isMoving = true;
+        private void Mouse_MouseUp(object sender, MouseButtonEventArgs e)
+            m_isMoving = false;
+        private void Mouse_MouseMove(object sender, MouseEventArgs e)
+            Point mouse = e.GetPosition(x_contentControl);
+            Vector3 world = m_renderEngine.ConvertToWorldCoordinates(mouse, (float)x_contentControl.ActualWidth, (float)x_contentControl.ActualHeight);
+            PositionString = string.Format(
+                CultureInfo.InvariantCulture,
+                "[{0},{1}]  X={2}  Y={3}  Z={4}",
+                mouse.X,
+                mouse.Y,
+                world.X.ToString("F1", CultureInfo.InvariantCulture),
+                world.Y.ToString("F1", CultureInfo.InvariantCulture),
+                world.Z.ToString("F1", CultureInfo.InvariantCulture));
+                if (m_isMoving)
+                    Point currPoint = e.GetPosition(x_contentControl);
+                    Vector3 camera = m_renderEngine.CameraPosition;
+                    Vector3 target = m_renderEngine.TargetPosition;
+                    camera.X += (float)(m_downPoint.X - currPoint.X) / 100.0f;
+                    target.X += (float)(m_downPoint.X - currPoint.X) / 100.0f;
+                    camera.Y += -(float)(m_downPoint.Y - currPoint.Y) / 100.0f;
+                    target.Y += -(float)(m_downPoint.Y - currPoint.Y) / 100.0f;
+                    m_renderEngine.CameraPosition = camera;
+                    m_renderEngine.TargetPosition = target;
+                    m_downPoint = currPoint;
+            return;
+        private void Mouse_MouseWheel(object sender, MouseWheelEventArgs e)
+            camera.Z += e.Delta / 100.0f;
+        #endregion
+        private Vector4[] CreateData()
+            Vector4 red = new Vector4(1, 0, 0, 1);
+            Vector4 green = new Vector4(0, 1, 0, 1);
+            Vector4 blue = new Vector4(0, 0, 1, 1);
+            List<Vector4> points = new List<Vector4>();
+            System.Random rand = new System.Random();
+            for (int p = 0; p < 1000; p++)
+                float x = (float)rand.NextDouble() * 100;
+                float y = (float)rand.NextDouble() * 10 + 45;
+                float z = (float)rand.NextDouble() * 100;
+                points.Add(new Vector4(x, y, z, 1));
+                float r = (float)rand.NextDouble();
+                float g = (float)rand.NextDouble();
+                float b = (float)rand.NextDouble();
+                points.Add(new Vector4(r, g, b, 1));
+            return points.ToArray();
+        #region INotifyPropertyChanged
+        public event PropertyChangedEventHandler PropertyChanged;
+        private void NotifyPropertyChanged(string info)
+            if (PropertyChanged != null)
+                PropertyChanged(this, new PropertyChangedEventArgs(info));
+        #endregion
diff -r d0ca3d54fcdb -r 23e91f43b490 csharp/PCView/Mouse.fx
--- a/csharp/PCView/Mouse.fx	Fri Mar 04 12:39:35 2011 -0800
+++ /dev/null	Thu Jan 01 00:00:00 1970 +0000
@@ -1,35 +0,0 @@
-cbuffer cbPerObject
-    float4x4 gWVP;
-// VertexShader
-void VS(float4 inputPos: POSITION,
-        float4 inputCol: COLOR,
-        out float4 outputPos : SV_POSITION,
-        out float4 outputCol : COLOR)
-    //PS_IN output = (PS_IN)0;
-    outputPos = mul(inputPos, gWVP);
-    outputCol = inputCol;
-// PixelShader
-void PS(float4 inputPos: SV_POSITION,
-        out float4 outputCol: SV_TARGET)
-technique10 Render
-    pass P0
-        SetGeometryShader( 0 );
-        SetVertexShader( CompileShader( vs_4_0, VS() ) );
-        SetPixelShader( CompileShader( ps_4_0, PS() ) );
diff -r d0ca3d54fcdb -r 23e91f43b490 csharp/PCView/Mouse.xaml
--- a/csharp/PCView/Mouse.xaml	Fri Mar 04 12:39:35 2011 -0800
@@ -1,14 +0,0 @@
-<Window x:Class="Flaxen.SlimDXControlLib.MouseExample.Mouse"
-    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
-    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
-    xmlns:d3d="clr-namespace:Flaxen.SlimDXControlLib;assembly=Flaxen.SlimDXControlLib"
-    Title="Mouse Example"
-    Width="500"
-    Height="500">
-    <DockPanel LastChildFill="True" >
-        <TextBlock DockPanel.Dock="Bottom" Text="{Binding Path=PositionString}" />
-        <d3d:SlimDXControl DockPanel.Dock="Top" x:Name="x_contentControl" />
-    </DockPanel>
-</Window>
diff -r d0ca3d54fcdb -r 23e91f43b490 csharp/PCView/Mouse.xaml.cs
--- a/csharp/PCView/Mouse.xaml.cs	Fri Mar 04 12:39:35 2011 -0800
@@ -1,205 +0,0 @@
-// <copyright file="Mouse.xaml.cs" company="Flaxen Geo">
-//    Copyright (c) 2011, Michael P. Gerlek.  All rights reserved.
-// </copyright>
-// Redistribution and use in source and binary forms, with or without
-// modification, are permitted provided that the following conditions are
-// met:
More information about the Liblas-commits mailing list
