[Liblas-commits] hg-main-tree: set libpc_test data directory from the command line
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Mar 16 15:13:25 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/cd1a23c1b289
changeset: 289:cd1a23c1b289
user:      Kirk McKelvey <kirkoman at gmail.com>
date:      Wed Mar 16 13:23:10 2011 -0500
description:
Subject: hg-main-tree: merge
details:   http://hg.libpc.orghg-main-tree/rev/be26be68d21c
changeset: 290:be26be68d21c
date:      Wed Mar 16 14:13:18 2011 -0500
description:
merge
diffstat:
 include/libpc/Filter.hpp                   |   5 -
 include/libpc/Iterator.hpp                 |  52 ++++++++++++++++++
 include/libpc/Reader.hpp                   |   4 -
 include/libpc/drivers/oci/Reader.hpp       |   2 +
 include/libpc/filters/CropFilter.hpp       |   2 +
 include/libpc/filters/DecimationFilter.hpp |   2 +
 include/libpc/filters/MosaicFilter.hpp     |   2 +-
 src/CMakeLists.txt                         |   3 +-
 src/Filter.cpp                             |   6 --
 src/Iterator.cpp                           |  85 ++++++++++++++++++++++++++++++
 src/Reader.cpp                             |  19 ------
 src/drivers/oci/Reader.cpp                 |  20 +++++++
 src/filters/CropFilter.cpp                 |   6 ++
 src/filters/DecimationFilter.cpp           |   6 ++
 src/filters/MosaicFilter.cpp               |   6 ++
 test/unit/CMakeLists.txt                   |   2 +-
 test/unit/ChipperTest.cpp                  |   4 +-
 test/unit/CropFilterTest.cpp               |  18 +++---
 test/unit/LiblasReaderTest.cpp             |   4 +-
 test/unit/LiblasWriterTest.cpp             |  10 ++-
 test/unit/main.cpp                         |  53 ++++++++++++++---
 21 files changed, 247 insertions(+), 64 deletions(-)
diffs (truncated from 567 to 300 lines):
diff -r e42e3d5bfd7e -r be26be68d21c include/libpc/Filter.hpp
--- a/include/libpc/Filter.hpp	Wed Mar 16 12:11:43 2011 -0500
+++ b/include/libpc/Filter.hpp	Wed Mar 16 14:13:18 2011 -0500
@@ -48,11 +48,6 @@
     Filter(Stage& prevStage);
 protected:
-    // advance (or retreat) to the Nth point in the file (absolute,
-    // default behaviour for filters is just to call seek on the previous stage
-    virtual void seekToPoint(boost::uint64_t pointNum);
-protected:
     Stage& m_prevStage;
 private:
diff -r e42e3d5bfd7e -r be26be68d21c include/libpc/Iterator.hpp
--- a/include/libpc/Iterator.hpp	Wed Mar 16 12:11:43 2011 -0500
+++ b/include/libpc/Iterator.hpp	Wed Mar 16 14:13:18 2011 -0500
@@ -40,7 +40,59 @@
 namespace libpc
+class LIBPC_DLL Iterator
+public:
+    Iterator(const Stage& stage);
+    const Stage& getStage() const;
+    // This reads a set of points at the current position in the file.
+    // The schema of the PointData buffer we are given here might
+    // not match our own header's schema.  That's okay, though: all
+    // that matters is that the buffer we are given has the fields
+    // we need to write into.
+    // This is NOT virtual.  Derived classes should override the
+    // readBuffer function below, not this one.
+    // Returns the number of valid points read.
+    boost::uint32_t read(PointData&);
+    // advance (or retreat) to the Nth point in the file (absolute,
+    // not relative).  In some cases, this might be a very slow, painful
+    // function to call.
+    virtual void seekToPoint(boost::uint64_t pointNum) = 0;
+    // Returns the current point number.  The first point is 0.
+    // If this number if > getNumPoints(), then no more points
+    // may be read (and atEnd() should be true).
+    boost::uint64_t getCurrentPointIndex() const;
+    // returns true after we've read all the points available to this stage
+    // (actually a convenience function that compares getCurrentPointIndex and getNumPoints)
+    bool atEnd() const;
+protected:
+    // Implement this to do the actual work to fill in a buffer of points.
+    virtual boost::uint32_t readBuffer(PointData&) = 0;
+    // Each concrete stage is repsonsible for managing its own current
+    // point index when a read or seek occurs.  Call this function to set
+    // the value.
+    void setCurrentPointIndex(boost::uint64_t delta);
+    // this is easier than saying setCurrentPointIndex(getCurrentPointIndex()+n)
+    void incrementCurrentPointIndex(boost::uint64_t currentPointDelta);
+private:
+    const Stage& m_stage;
+    boost::uint64_t m_currentPointIndex;
+    Iterator& operator=(const Iterator&); // not implemented
+    Iterator(const Iterator&); // not implemented
 } // namespace libpc
diff -r e42e3d5bfd7e -r be26be68d21c include/libpc/Reader.hpp
--- a/include/libpc/Reader.hpp	Wed Mar 16 12:11:43 2011 -0500
+++ b/include/libpc/Reader.hpp	Wed Mar 16 14:13:18 2011 -0500
@@ -46,10 +46,6 @@
 public:
     Reader();
-    // default is to read N points manually
-    // override this if you can
 private:
     Reader& operator=(const Reader&); // not implemented
     Reader(const Reader&); // not implemented
diff -r e42e3d5bfd7e -r be26be68d21c include/libpc/drivers/oci/Reader.hpp
--- a/include/libpc/drivers/oci/Reader.hpp	Wed Mar 16 12:11:43 2011 -0500
+++ b/include/libpc/drivers/oci/Reader.hpp	Wed Mar 16 14:13:18 2011 -0500
@@ -57,6 +57,8 @@
     ~Reader();
     const std::string& getName() const;
+    void seekToPoint(boost::uint64_t pointNum);
 private:
diff -r e42e3d5bfd7e -r be26be68d21c include/libpc/filters/CropFilter.hpp
--- a/include/libpc/filters/CropFilter.hpp	Wed Mar 16 12:11:43 2011 -0500
+++ b/include/libpc/filters/CropFilter.hpp	Wed Mar 16 14:13:18 2011 -0500
@@ -50,6 +50,8 @@
 private:
     boost::uint32_t readBuffer(PointData&);
diff -r e42e3d5bfd7e -r be26be68d21c include/libpc/filters/DecimationFilter.hpp
--- a/include/libpc/filters/DecimationFilter.hpp	Wed Mar 16 12:11:43 2011 -0500
+++ b/include/libpc/filters/DecimationFilter.hpp	Wed Mar 16 14:13:18 2011 -0500
@@ -50,6 +50,8 @@
 private:
diff -r e42e3d5bfd7e -r be26be68d21c include/libpc/filters/MosaicFilter.hpp
--- a/include/libpc/filters/MosaicFilter.hpp	Wed Mar 16 12:11:43 2011 -0500
+++ b/include/libpc/filters/MosaicFilter.hpp	Wed Mar 16 14:13:18 2011 -0500
@@ -49,7 +49,7 @@
-    // BUG: what does seetToPoint() do for a mosaic filter?
 private:
diff -r e42e3d5bfd7e -r be26be68d21c src/CMakeLists.txt
--- a/src/CMakeLists.txt	Wed Mar 16 12:11:43 2011 -0500
+++ b/src/CMakeLists.txt	Wed Mar 16 14:13:18 2011 -0500
@@ -41,7 +41,6 @@
   ${LIBPC_HEADERS_DIR}/DimensionLayout.hpp
   ${LIBPC_HEADERS_DIR}/Filter.hpp
   ${LIBPC_HEADERS_DIR}/Header.hpp
-  ${LIBPC_HEADERS_DIR}/Iterator.hpp
   ${LIBPC_HEADERS_DIR}/Metadata.hpp
   ${LIBPC_HEADERS_DIR}/Vector.hpp
   ${LIBPC_HEADERS_DIR}/PointData.hpp
@@ -199,7 +198,7 @@
   ${LIBPC_HEADERS_DIR}/filters/MosaicFilter.hpp
-set (LIBPC_FILTERS_HPP
+set (LIBPC_FILTERS_CPP
   ./filters/CacheFilter.cpp
   ./filters/ColorFilter.cpp
   ./filters/CropFilter.cpp
diff -r e42e3d5bfd7e -r be26be68d21c src/Filter.cpp
--- a/src/Filter.cpp	Wed Mar 16 12:11:43 2011 -0500
+++ b/src/Filter.cpp	Wed Mar 16 14:13:18 2011 -0500
@@ -48,10 +48,4 @@
-void Filter::seekToPoint(boost::uint64_t pointNum)
-    m_prevStage.seekToPoint(pointNum);
diff -r e42e3d5bfd7e -r be26be68d21c src/Iterator.cpp
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/src/Iterator.cpp	Wed Mar 16 14:13:18 2011 -0500
@@ -0,0 +1,85 @@
+* Copyright (c) 2011, Michael P. Gerlek (mpg at flaxen.com)
+* All rights reserved.
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following
+* conditions are met:
+*     * Redistributions of source code must retain the above copyright
+*       notice, this list of conditions and the following disclaimer.
+*     * Redistributions in binary form must reproduce the above copyright
+*       notice, this list of conditions and the following disclaimer in
+*       the documentation and/or other materials provided
+*       with the distribution.
+*     * Neither the name of Hobu, Inc. or Flaxen Geo Consulting nor the
+*       names of its contributors may be used to endorse or promote
+*       products derived from this software without specific prior
+*       written permission.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+* OF SUCH DAMAGE.
+#include <libpc/Iterator.hpp>
+namespace libpc
+Iterator::Iterator(const Stage& stage)
+    : m_stage(stage)
+    , m_currentPointIndex(0)
+    return;
+const Stage& Iterator::getStage() const
+    return m_stage;
+void Iterator::setCurrentPointIndex(boost::uint64_t currentPointIndex)
+    m_currentPointIndex = currentPointIndex;
+boost::uint64_t Iterator::getCurrentPointIndex() const
+    return m_currentPointIndex;
+void Iterator::incrementCurrentPointIndex(boost::uint64_t delta)
+    m_currentPointIndex += delta;
+boost::uint32_t Iterator::read(PointData& data)
+    const boost::uint32_t numPointsRead = readBuffer(data);
+    return numPointsRead;
+bool Iterator::atEnd() const
+    return getCurrentPointIndex() >= getStage().getNumPoints();
+} // namespace libpc
diff -r e42e3d5bfd7e -r be26be68d21c src/Reader.cpp
--- a/src/Reader.cpp	Wed Mar 16 12:11:43 2011 -0500
+++ b/src/Reader.cpp	Wed Mar 16 14:13:18 2011 -0500
@@ -44,24 +44,5 @@
-void Reader::seekToPoint(boost::uint64_t pointNum)
-    if (pointNum == getCurrentPointIndex())
-        return;
-    setCurrentPointIndex(0);
-    // we read the points only to get to the right place -- we
-    // will just drop the points on the floor and return
-    boost::uint32_t pointNumX = (boost::uint32_t)pointNum; // BUG
-    assert(pointNumX == pointNum);
-    PointData pointData(getHeader().getSchema(), pointNumX);
-    read(pointData);
-    return;
diff -r e42e3d5bfd7e -r be26be68d21c src/drivers/oci/Reader.cpp
--- a/src/drivers/oci/Reader.cpp	Wed Mar 16 12:11:43 2011 -0500
+++ b/src/drivers/oci/Reader.cpp	Wed Mar 16 14:13:18 2011 -0500
@@ -73,5 +73,25 @@
     return;
+void Reader::seekToPoint(boost::uint64_t pointNum)
More information about the Liblas-commits mailing list
