[Liblas-commits] hg-main-tree: removed Reader class; add some iter support code
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Mar 17 13:26:48 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/898dbce5a9b9
changeset: 332:898dbce5a9b9
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Thu Mar 17 13:12:31 2011 -0400
description:
Subject: hg-main-tree: merge
details:   http://hg.libpc.orghg-main-tree/rev/517a086b3e6e
changeset: 333:517a086b3e6e
date:      Thu Mar 17 13:12:51 2011 -0400
description:
merge
Subject: hg-main-tree: repair init order
details:   http://hg.libpc.orghg-main-tree/rev/9821c483080e
changeset: 334:9821c483080e
date:      Thu Mar 17 13:26:18 2011 -0400
description:
repair init order
diffstat:
 apps/pcinfo.cpp                            |   2 +-
 cmake/modules/FindMrSID.cmake              |  58 ++++++++++++++++++++++++++++++
 include/libpc/Iterator.hpp                 |  14 ++++---
 include/libpc/Reader.hpp                   |  56 ----------------------------
 include/libpc/Stage.hpp                    |  14 ++++--
 include/libpc/Writer.hpp                   |   2 +-
 include/libpc/drivers/faux/Reader.hpp      |   6 ++-
 include/libpc/drivers/las/Reader.hpp       |   6 ++-
 include/libpc/drivers/liblas/Reader.hpp    |   6 ++-
 include/libpc/filters/CacheFilter.hpp      |   2 +
 include/libpc/filters/ColorFilter.hpp      |   2 +
 include/libpc/filters/CropFilter.hpp       |   2 +
 include/libpc/filters/DecimationFilter.hpp |   2 +
 include/libpc/filters/MosaicFilter.hpp     |   2 +
 src/CMakeLists.txt                         |   4 +-
 src/Iterator.cpp                           |   3 +-
 src/Reader.cpp                             |  48 ------------------------
 src/drivers/CMakeLists.txt                 |   4 ++
 src/drivers/faux/Reader.cpp                |  10 ++++-
 src/drivers/las/Reader.cpp                 |  12 +++++-
 src/drivers/liblas/Reader.cpp              |  11 ++++-
 src/drivers/oci/Writer.cpp                 |   4 +-
 src/filters/CacheFilter.cpp                |   8 ++++
 src/filters/ColorFilter.cpp                |   7 +++
 src/filters/CropFilter.cpp                 |  12 +++++-
 src/filters/DecimationFilter.cpp           |   8 ++++
 src/filters/MosaicFilter.cpp               |  14 ++++++-
 test/unit/CacheFilterTest.cpp              |  11 ++---
 test/unit/ChipperTest.cpp                  |   4 +-
 test/unit/LiblasReaderTest.cpp             |   5 +-
 test/unit/LiblasWriterTest.cpp             |  10 ++---
 test/unit/main.cpp                         |  47 ++----------------------
 test/unit/support.cpp                      |  13 ++++++
 test/unit/support.hpp                      |   5 ++
 34 files changed, 216 insertions(+), 198 deletions(-)
diffs (truncated from 970 to 300 lines):
diff -r 0ab6915ad1d7 -r 9821c483080e apps/pcinfo.cpp
--- a/apps/pcinfo.cpp	Thu Mar 17 11:06:31 2011 -0400
+++ b/apps/pcinfo.cpp	Thu Mar 17 13:26:18 2011 -0400
@@ -78,7 +78,7 @@
     std::istream* ifs = Utils::openFile(m_inputFile);
-    libpc::Reader* reader = NULL;
+    libpc::Stage* reader = NULL;
     if (hasOption("native"))
         reader = new libpc::drivers::las::LasReader(*ifs);
diff -r 0ab6915ad1d7 -r 9821c483080e cmake/modules/FindMrSID.cmake
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/cmake/modules/FindMrSID.cmake	Thu Mar 17 13:26:18 2011 -0400
@@ -0,0 +1,58 @@
+# CMake module to search for MrSID/MG4 libraries
+# On success, the macro sets the following variables:
+# MRSID_FOUND        = if the library was found
+# MRSID_LIBRARY      = full path to the library
+# MRSID_INCLUDE_DIR  = full path to the headers
+# MRSID_VERSION      = version of library which was found
+# Copyright (c) 2009 Mateusz Loskot <mateusz at loskot.net>
+# Developed with inspiration from Petr Vanek <petr at scribus.info>
+# who wrote similar macro for TOra - http://torasql.com/
+# Module source: http://github.com/mloskot/workshop/tree/master/cmake/
+# Redistribution and use is allowed according to the terms of the BSD license.
+# For details see the accompanying COPYING-CMAKE-SCRIPTS file.
+if(MRSID_INCLUDE_DIR AND MRSID_LIBRARY)
+  # Already in cache, be silent
+  set(MRSID_FIND_QUIETLY TRUE)
+endif()
+if(NOT MRSID_FIND_QUIETLY)
+  message(STATUS "Searching for MrSID LiDAR library ${MrSID_FIND_VERSION}+")
+endif()
+if(NOT DEFINED ENV{MRSID_HOME})
+  message(FATAL_ERROR "Missing environment variable MRSID_HOME with location of MrSID LiDAR sdk")
+endif()
+set(MRSID_HOME $ENV{MRSID_HOME})
+find_path(MRSID_INCLUDE_DIR
+          lidar/Base.h
+          PATHS
+            ${MRSID_HOME}/include
+            ${MRSID_HOME}/Lidar_DSDK/include
+          NO_DEFAULT_PATH)
+find_library(MRSID_LIBRARY
+             NAMES
+               lti_lidar_dsdk
+               liblti_lidar_dsdk
+             HINTS
+               ${MRSID_INCLUDE_DIR}/../lib
+             NO_DEFAULT_PATH)
+# Handle the QUIETLY and REQUIRED arguments and set MRSID_FOUND to TRUE
+# if all listed variables are TRUE
+include(FindPackageHandleStandardArgs)
+find_package_handle_standard_args(MrSID DEFAULT_MSG MRSID_LIBRARY MRSID_INCLUDE_DIR)
diff -r 0ab6915ad1d7 -r 9821c483080e include/libpc/Iterator.hpp
--- a/include/libpc/Iterator.hpp	Thu Mar 17 11:06:31 2011 -0400
+++ b/include/libpc/Iterator.hpp	Thu Mar 17 13:26:18 2011 -0400
@@ -36,6 +36,7 @@
 #define INCLUDED_ITERATOR_HPP
 #include <libpc/Stage.hpp>
+#include <libpc/Bounds.hpp>
 namespace libpc
@@ -43,7 +44,7 @@
 class LIBPC_DLL Iterator
 public:
-    Iterator(const Stage& stage);
+    Iterator(const Stage& stage, const Bounds<double>& bounds);
     const Stage& getStage() const;
@@ -65,16 +66,16 @@
     // function to call.
     virtual void seekToPoint(boost::uint64_t pointNum) = 0;
+    // returns true after we've read all the points available to this stage
+    // (actually a convenience function that compares getCurrentPointIndex and getNumPoints)
+    bool atEnd() const;
+protected:
     // Returns the current point number.  The first point is 0.
     // If this number if > getNumPoints(), then no more points
     // may be read (and atEnd() should be true).
     boost::uint64_t getCurrentPointIndex() const;
-    // returns true after we've read all the points available to this stage
-    // (actually a convenience function that compares getCurrentPointIndex and getNumPoints)
-    bool atEnd() const;
-protected:
     // Implement this to do the actual work to fill in a buffer of points.
     virtual boost::uint32_t readBuffer(PointData&) = 0;
@@ -89,6 +90,7 @@
 private:
     const Stage& m_stage;
     boost::uint64_t m_currentPointIndex;
+    const Bounds<double> m_bounds;
     Iterator& operator=(const Iterator&); // not implemented
     Iterator(const Iterator&); // not implemented
diff -r 0ab6915ad1d7 -r 9821c483080e include/libpc/Reader.hpp
--- a/include/libpc/Reader.hpp	Thu Mar 17 11:06:31 2011 -0400
+++ /dev/null	Thu Jan 01 00:00:00 1970 +0000
@@ -1,56 +0,0 @@
-* Copyright (c) 2011, Michael P. Gerlek (mpg at flaxen.com)
-* All rights reserved.
-* Redistribution and use in source and binary forms, with or without
-* modification, are permitted provided that the following
-* conditions are met:
-*     * Redistributions of source code must retain the above copyright
-*       notice, this list of conditions and the following disclaimer.
-*     * Redistributions in binary form must reproduce the above copyright
-*       notice, this list of conditions and the following disclaimer in
-*       the documentation and/or other materials provided
-*       with the distribution.
-*     * Neither the name of Hobu, Inc. or Flaxen Geo Consulting nor the
-*       names of its contributors may be used to endorse or promote
-*       products derived from this software without specific prior
-*       written permission.
-* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
-* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
-* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
-* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
-* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
-* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
-* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
-* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
-* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
-* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
-* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
-* OF SUCH DAMAGE.
-#ifndef INCLUDED_READER_HPP
-#define INCLUDED_READER_HPP
-#include <libpc/Stage.hpp>
-#include <libpc/Header.hpp>
-namespace libpc
-class LIBPC_DLL Reader : public Stage
-public:
-    Reader();
-private:
-    Reader& operator=(const Reader&); // not implemented
-    Reader(const Reader&); // not implemented
-} // namespace libpc
-#endif
diff -r 0ab6915ad1d7 -r 9821c483080e include/libpc/Stage.hpp
--- a/include/libpc/Stage.hpp	Thu Mar 17 11:06:31 2011 -0400
+++ b/include/libpc/Stage.hpp	Thu Mar 17 13:26:18 2011 -0400
@@ -45,6 +45,8 @@
 namespace libpc
+class Iterator;
 // every stage owns its own header, they are not shared
 class LIBPC_DLL Stage
@@ -75,11 +77,6 @@
-    // Returns the current point number.  The first point is 0.
-    // If this number if > getNumPoints(), then no more points
-    // may be read (and atEnd() should be true).
-    boost::uint64_t getCurrentPointIndex() const;
     // returns the number of points this stage has available
     // (actually a convenience function that gets it from the header)
     boost::uint64_t getNumPoints() const;
@@ -91,6 +88,8 @@
     const Header& getHeader() const;
     Header& getHeader();
+    virtual Iterator* createIterator(const Bounds<double>& bounds) = 0;
 protected:
     virtual boost::uint32_t readBuffer(PointData& pointData, const Bounds<double>& bounds) = 0;
@@ -105,6 +104,11 @@
     void setHeader(Header*); // stage takes ownership
+        // Returns the current point number.  The first point is 0.
+    // If this number if > getNumPoints(), then no more points
+    // may be read (and atEnd() should be true).
+    boost::uint64_t getCurrentPointIndex() const;
 private:
     Header* m_header;
diff -r 0ab6915ad1d7 -r 9821c483080e include/libpc/Writer.hpp
--- a/include/libpc/Writer.hpp	Thu Mar 17 11:06:31 2011 -0400
+++ b/include/libpc/Writer.hpp	Thu Mar 17 13:26:18 2011 -0400
@@ -35,7 +35,7 @@
 #ifndef INCLUDED_WRITER_HPP
 #define INCLUDED_WRITER_HPP
-#include <libpc/Filter.hpp>
+#include <libpc/Stage.hpp>
 namespace libpc
diff -r 0ab6915ad1d7 -r 9821c483080e include/libpc/drivers/faux/Reader.hpp
--- a/include/libpc/drivers/faux/Reader.hpp	Thu Mar 17 11:06:31 2011 -0400
+++ b/include/libpc/drivers/faux/Reader.hpp	Thu Mar 17 13:26:18 2011 -0400
@@ -35,7 +35,7 @@
 #ifndef INCLUDED_DRIVERS_FAUX_READER_HPP
 #define INCLUDED_DRIVERS_FAUX_READER_HPP
-#include <libpc/Reader.hpp>
 namespace libpc { namespace drivers { namespace faux {
@@ -52,7 +52,7 @@
 // points to always be at the minimum of the bounding box.  The Time field
 // is always set to the point number.
-class LIBPC_DLL Reader : public libpc::Reader
+class LIBPC_DLL Reader : public libpc::Stage
 public:
     enum Mode
@@ -69,6 +69,8 @@
     void seekToPoint(boost::uint64_t);
+    Iterator* createIterator(const Bounds<double>& bounds);
 private:
     boost::uint32_t readBuffer(PointData&, const Bounds<double>& bounds);
diff -r 0ab6915ad1d7 -r 9821c483080e include/libpc/drivers/las/Reader.hpp
--- a/include/libpc/drivers/las/Reader.hpp	Thu Mar 17 11:06:31 2011 -0400
+++ b/include/libpc/drivers/las/Reader.hpp	Thu Mar 17 13:26:18 2011 -0400
@@ -37,13 +37,13 @@
 #include <iostream>
 #include <libpc/drivers/las/Header.hpp>
 namespace libpc { namespace drivers { namespace las {
-class LIBPC_DLL LasReader : public Reader
+class LIBPC_DLL LasReader : public Stage
 public:
     LasReader(std::istream&);
@@ -56,6 +56,8 @@
     const LasHeader& getLasHeader() const;
 protected:
     boost::uint32_t readBuffer(PointData& data, const Bounds<double>& bounds);
diff -r 0ab6915ad1d7 -r 9821c483080e include/libpc/drivers/liblas/Reader.hpp
More information about the Liblas-commits mailing list
