[Liblas-commits] hg-main-tree: do something if we read no points
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Mar 17 15:35:15 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/a0f966667a73
changeset: 348:a0f966667a73
user:      Howard Butler <hobu.inc at gmail.com>
date:      Thu Mar 17 14:30:11 2011 -0500
description:
Subject: hg-main-tree: don't multiple include _config
details:   http://hg.libpc.orghg-main-tree/rev/3d19a4f57339
changeset: 349:3d19a4f57339
date:      Thu Mar 17 14:30:39 2011 -0500
description:
Subject: hg-main-tree: don't include libpc_config.hpp right now
details:   http://hg.libpc.orghg-main-tree/rev/7489cbd08a78
changeset: 350:7489cbd08a78
date:      Thu Mar 17 14:31:14 2011 -0500
description:
Subject: hg-main-tree: merge
details:   http://hg.libpc.orghg-main-tree/rev/a04aceb325c4
changeset: 351:a04aceb325c4
date:      Thu Mar 17 14:35:05 2011 -0500
description:
merge
diffstat:
 include/libpc/Stage.hpp                    |   4 ++--
 include/libpc/drivers/faux/Reader.hpp      |   2 +-
 include/libpc/drivers/las/Reader.hpp       |   2 +-
 include/libpc/drivers/liblas/Reader.hpp    |   2 +-
 include/libpc/filters/CacheFilter.hpp      |   2 +-
 include/libpc/filters/ColorFilter.hpp      |   2 +-
 include/libpc/filters/CropFilter.hpp       |   2 +-
 include/libpc/filters/DecimationFilter.hpp |   2 +-
 include/libpc/filters/MosaicFilter.hpp     |   2 +-
 include/libpc/libpc.hpp                    |   2 +-
 src/Chipper.cpp                            |   3 +--
 src/Stage.cpp                              |   4 ++--
 src/Writer.cpp                             |   4 +---
 src/drivers/faux/Reader.cpp                |   4 ++--
 src/drivers/las/Reader.cpp                 |   5 ++---
 src/drivers/liblas/Reader.cpp              |   2 +-
 src/drivers/liblas/Writer.cpp              |   1 -
 src/drivers/oci/Reader.cpp                 |   1 -
 src/drivers/oci/Writer.cpp                 |   3 +--
 src/filters/CacheFilter.cpp                |   6 +++---
 src/filters/ColorFilter.cpp                |   4 ++--
 src/filters/CropFilter.cpp                 |   8 +++++---
 src/filters/DecimationFilter.cpp           |   6 +++---
 src/filters/MosaicFilter.cpp               |   4 ++--
 test/unit/CacheFilterTest.cpp              |   8 +++-----
 test/unit/DecimationFilterTest.cpp         |   4 +---
 test/unit/FauxReaderTest.cpp               |   8 ++------
 test/unit/FauxWriterTest.cpp               |  18 +++++++++---------
 test/unit/LiblasReaderTest.cpp             |   7 +++----
 test/unit/MosaicFilterTest.cpp             |   4 +---
 30 files changed, 55 insertions(+), 71 deletions(-)
diffs (truncated from 540 to 300 lines):
diff -r c0f0c4b82e52 -r a04aceb325c4 include/libpc/Stage.hpp
--- a/include/libpc/Stage.hpp	Thu Mar 17 15:11:02 2011 -0400
+++ b/include/libpc/Stage.hpp	Thu Mar 17 14:35:05 2011 -0500
@@ -70,7 +70,7 @@
     // readBuffer function below, not this one.
     // Returns the number of valid points read.
-    boost::uint32_t read(PointData&, const Bounds<double>& bounds);
+    boost::uint32_t read(PointData&);
     // advance (or retreat) to the Nth point in the file (absolute,
     // not relative).  In some cases, this might be a very slow, painful
@@ -92,7 +92,7 @@
 protected:
     // Implement this to do the actual work to fill in a buffer of points.
-    virtual boost::uint32_t readBuffer(PointData& pointData, const Bounds<double>& bounds) = 0;
+    virtual boost::uint32_t readBuffer(PointData& pointData) = 0;
     // Each concrete stage is repsonsible for managing its own current
     // point index when a read or seek occurs.  Call this function to set
diff -r c0f0c4b82e52 -r a04aceb325c4 include/libpc/drivers/faux/Reader.hpp
--- a/include/libpc/drivers/faux/Reader.hpp	Thu Mar 17 15:11:02 2011 -0400
+++ b/include/libpc/drivers/faux/Reader.hpp	Thu Mar 17 14:35:05 2011 -0500
@@ -72,7 +72,7 @@
     Iterator* createIterator(const Bounds<double>& bounds);
 private:
-    boost::uint32_t readBuffer(PointData&, const Bounds<double>& bounds);
+    boost::uint32_t readBuffer(PointData&);
     Mode m_mode;
diff -r c0f0c4b82e52 -r a04aceb325c4 include/libpc/drivers/las/Reader.hpp
--- a/include/libpc/drivers/las/Reader.hpp	Thu Mar 17 15:11:02 2011 -0400
+++ b/include/libpc/drivers/las/Reader.hpp	Thu Mar 17 14:35:05 2011 -0500
@@ -59,7 +59,7 @@
 protected:
-    boost::uint32_t readBuffer(PointData& data, const Bounds<double>& bounds);
+    boost::uint32_t readBuffer(PointData& data);
     LasHeader& getLasHeader();
     void setLasHeader(const LasHeader&);
diff -r c0f0c4b82e52 -r a04aceb325c4 include/libpc/drivers/liblas/Reader.hpp
--- a/include/libpc/drivers/liblas/Reader.hpp	Thu Mar 17 15:11:02 2011 -0400
+++ b/include/libpc/drivers/liblas/Reader.hpp	Thu Mar 17 14:35:05 2011 -0500
@@ -67,7 +67,7 @@
 private:
-    virtual boost::uint32_t readBuffer(PointData& data, const Bounds<double>& bounds);
+    virtual boost::uint32_t readBuffer(PointData& data);
     LiblasHeader& getLiblasHeader();
     void setLiblasHeader(const LiblasHeader&);
diff -r c0f0c4b82e52 -r a04aceb325c4 include/libpc/filters/CacheFilter.hpp
--- a/include/libpc/filters/CacheFilter.hpp	Thu Mar 17 15:11:02 2011 -0400
+++ b/include/libpc/filters/CacheFilter.hpp	Thu Mar 17 14:35:05 2011 -0500
@@ -80,7 +80,7 @@
 private:
     boost::uint64_t m_numPointsRequested;
     boost::uint64_t m_numPointsRead;
diff -r c0f0c4b82e52 -r a04aceb325c4 include/libpc/filters/ColorFilter.hpp
--- a/include/libpc/filters/ColorFilter.hpp	Thu Mar 17 15:11:02 2011 -0400
+++ b/include/libpc/filters/ColorFilter.hpp	Thu Mar 17 14:35:05 2011 -0500
@@ -54,7 +54,7 @@
 private:
     void checkImpedance();
     void getColor(float value, boost::uint8_t& red, boost::uint8_t& green, boost::uint8_t& blue);
diff -r c0f0c4b82e52 -r a04aceb325c4 include/libpc/filters/CropFilter.hpp
--- a/include/libpc/filters/CropFilter.hpp	Thu Mar 17 15:11:02 2011 -0400
+++ b/include/libpc/filters/CropFilter.hpp	Thu Mar 17 14:35:05 2011 -0500
@@ -55,7 +55,7 @@
 private:
     Bounds<double> m_bounds;
diff -r c0f0c4b82e52 -r a04aceb325c4 include/libpc/filters/DecimationFilter.hpp
--- a/include/libpc/filters/DecimationFilter.hpp	Thu Mar 17 15:11:02 2011 -0400
+++ b/include/libpc/filters/DecimationFilter.hpp	Thu Mar 17 14:35:05 2011 -0500
@@ -55,7 +55,7 @@
 private:
     int m_step;
diff -r c0f0c4b82e52 -r a04aceb325c4 include/libpc/filters/MosaicFilter.hpp
--- a/include/libpc/filters/MosaicFilter.hpp	Thu Mar 17 15:11:02 2011 -0400
+++ b/include/libpc/filters/MosaicFilter.hpp	Thu Mar 17 14:35:05 2011 -0500
@@ -54,7 +54,7 @@
 private:
     std::vector<Stage*> m_prevStages;
diff -r c0f0c4b82e52 -r a04aceb325c4 include/libpc/libpc.hpp
--- a/include/libpc/libpc.hpp	Thu Mar 17 15:11:02 2011 -0400
+++ b/include/libpc/libpc.hpp	Thu Mar 17 14:35:05 2011 -0500
@@ -37,7 +37,7 @@
 #include <libpc/export.hpp>
 #include <libpc/libpc_defines.h>
-#include <libpc/libpc_config.hpp>
+// #include <libpc/libpc_config.hpp>
 #include <libpc/types.hpp>
 #endif
diff -r c0f0c4b82e52 -r a04aceb325c4 src/Chipper.cpp
--- a/src/Chipper.cpp	Thu Mar 17 15:11:02 2011 -0400
+++ b/src/Chipper.cpp	Thu Mar 17 14:35:05 2011 -0500
@@ -136,8 +136,7 @@
         PointData buffer(schema, num_to_read);
-        const Bounds<double>& bounds = Bounds<double>::getDefaultSpatialExtent();
-        boost::uint32_t num_read =  m_stage.read(buffer, bounds);
+        boost::uint32_t num_read =  m_stage.read(buffer);
         if (num_read == 0) break;
         assert(num_read <= num_to_read);
diff -r c0f0c4b82e52 -r a04aceb325c4 src/Stage.cpp
--- a/src/Stage.cpp	Thu Mar 17 15:11:02 2011 -0400
+++ b/src/Stage.cpp	Thu Mar 17 14:35:05 2011 -0500
@@ -91,9 +91,9 @@
-boost::uint32_t Stage::read(PointData& data, const Bounds<double>& bounds)
+boost::uint32_t Stage::read(PointData& data)
-    const boost::uint32_t numPointsRead = readBuffer(data, bounds);
+    const boost::uint32_t numPointsRead = readBuffer(data);
     return numPointsRead;
diff -r c0f0c4b82e52 -r a04aceb325c4 src/Writer.cpp
--- a/src/Writer.cpp	Thu Mar 17 15:11:02 2011 -0400
+++ b/src/Writer.cpp	Thu Mar 17 14:35:05 2011 -0500
@@ -73,8 +73,6 @@
 boost::uint64_t Writer::write(std::size_t targetNumPointsToWrite)
-    const Bounds<double>& maxBounds = Bounds<double>::getDefaultSpatialExtent();
     m_targetNumPointsToWrite = targetNumPointsToWrite;
     m_actualNumPointsWritten = 0;
@@ -87,7 +85,7 @@
         PointData buffer(m_prevStage.getHeader().getSchema(), numPointsToReadThisChunk);
-        boost::uint32_t numPointsReadThisChunk = m_prevStage.read(buffer, maxBounds);
+        boost::uint32_t numPointsReadThisChunk = m_prevStage.read(buffer);
         assert(numPointsReadThisChunk <= numPointsToReadThisChunk);
         boost::uint32_t numPointsWrittenThisChunk = writeBuffer(buffer);
diff -r c0f0c4b82e52 -r a04aceb325c4 src/drivers/faux/Reader.cpp
--- a/src/drivers/faux/Reader.cpp	Thu Mar 17 15:11:02 2011 -0400
+++ b/src/drivers/faux/Reader.cpp	Thu Mar 17 14:35:05 2011 -0500
@@ -94,7 +94,7 @@
-boost::uint32_t Reader::readBuffer(PointData& data, const Bounds<double>& userBounds)
+boost::uint32_t Reader::readBuffer(PointData& data)
     if (data.getSchemaLayout().getSchema().getDimensions().size() != 4)
         throw not_yet_implemented("need to add ability to read from arbitrary fields");
@@ -166,7 +166,7 @@
-Iterator* Reader::createIterator(const Bounds<double>& bounds)
+Iterator* Reader::createIterator(const Bounds<double>&)
     throw not_yet_implemented("iterator");
diff -r c0f0c4b82e52 -r a04aceb325c4 src/drivers/las/Reader.cpp
--- a/src/drivers/las/Reader.cpp	Thu Mar 17 15:11:02 2011 -0400
+++ b/src/drivers/las/Reader.cpp	Thu Mar 17 14:35:05 2011 -0500
@@ -81,15 +81,14 @@
     // BUG: we can move the stream a constant amount
     PointData pointData(getHeader().getSchema(), chunk);
-    read(pointData, maxBounds);
+    read(pointData);
     // just drop the points on the floor and return
     return;
-boost::uint32_t LasReader::readBuffer(PointData& pointData, const Bounds<double>&)
+boost::uint32_t LasReader::readBuffer(PointData& pointData)
     boost::uint32_t numPoints = pointData.getCapacity();
diff -r c0f0c4b82e52 -r a04aceb325c4 src/drivers/liblas/Reader.cpp
--- a/src/drivers/liblas/Reader.cpp	Thu Mar 17 15:11:02 2011 -0400
+++ b/src/drivers/liblas/Reader.cpp	Thu Mar 17 14:35:05 2011 -0500
@@ -233,7 +233,7 @@
-boost::uint32_t LiblasReader::readBuffer(PointData& pointData, const Bounds<double>&)
+boost::uint32_t LiblasReader::readBuffer(PointData& pointData)
     boost::uint32_t i = 0;
diff -r c0f0c4b82e52 -r a04aceb325c4 src/drivers/liblas/Writer.cpp
--- a/src/drivers/liblas/Writer.cpp	Thu Mar 17 15:11:02 2011 -0400
+++ b/src/drivers/liblas/Writer.cpp	Thu Mar 17 14:35:05 2011 -0500
@@ -40,7 +40,6 @@
 #include <liblas/Writer.hpp>
 #include <libpc/exceptions.hpp>
 namespace libpc { namespace drivers { namespace liblas {
diff -r c0f0c4b82e52 -r a04aceb325c4 src/drivers/oci/Reader.cpp
--- a/src/drivers/oci/Reader.cpp	Thu Mar 17 15:11:02 2011 -0400
+++ b/src/drivers/oci/Reader.cpp	Thu Mar 17 14:35:05 2011 -0500
@@ -43,7 +43,6 @@
 #include <cstdlib>
 #include <iostream>
diff -r c0f0c4b82e52 -r a04aceb325c4 src/drivers/oci/Writer.cpp
--- a/src/drivers/oci/Writer.cpp	Thu Mar 17 15:11:02 2011 -0400
+++ b/src/drivers/oci/Writer.cpp	Thu Mar 17 14:35:05 2011 -0500
@@ -41,7 +41,6 @@
 #include <libpc/drivers/oci/Header.hpp>
 #include <cstdlib>
 #include <iostream>
@@ -951,7 +950,7 @@
             m_stage.seekToPoint(*it);
             // FIXME: Use a user bounds here instead of reading everything
-            m_stage.read(buffer, libpc::Bounds<double>());
+            m_stage.read(buffer);
             block.copyPointsFast(static_cast<std::size_t>(count), static_cast<std::size_t>(0), buffer, 1); // put single point onto our block
diff -r c0f0c4b82e52 -r a04aceb325c4 src/filters/CacheFilter.cpp
--- a/src/filters/CacheFilter.cpp	Thu Mar 17 15:11:02 2011 -0400
+++ b/src/filters/CacheFilter.cpp	Thu Mar 17 14:35:05 2011 -0500
@@ -113,7 +113,7 @@
-boost::uint32_t CacheFilter::readBuffer(PointData& data, const Bounds<double>& bounds)
+boost::uint32_t CacheFilter::readBuffer(PointData& data)
     const boost::uint64_t currentPointIndex = getCurrentPointIndex();
@@ -122,7 +122,7 @@
     // cached block to satisfy it)
     if (data.getCapacity() != 1)
-        const boost::uint32_t numRead = m_prevStage.read(data, bounds);
+        const boost::uint32_t numRead = m_prevStage.read(data);
         // if they asked for a full block and we got a full block,
         // and the block we got is properly aligned and not already cached,
@@ -161,7 +161,7 @@
     // Not in the cache, so do a normal read :-(
More information about the Liblas-commits mailing list
