[Liblas-commits] hg: AUTHORS
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Mar 24 11:23:28 EDT 2011
details:   http://hg.liblas.orghg/rev/f39c9a180450
changeset: 2903:f39c9a180450
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Thu Mar 24 08:23:07 2011 -0700
description:
AUTHORS
Subject: hg: merge
details:   http://hg.liblas.orghg/rev/b9d8c358259a
changeset: 2904:b9d8c358259a
date:      Thu Mar 24 08:23:22 2011 -0700
description:
merge
diffstat:
 AUTHORS                    |    2 +-
 apps/las2oci.cpp           |   37 ++-
 doc/development/wkt.txt    |    2 +-
 doc/download.txt           |    4 +-
 include/liblas/bounds.hpp  |    2 +-
 include/liblas/chipper.hpp |   56 ++-
 src/chipper.cpp            |  186 +++++++---
 src/detail/zippoint.cpp    |   18 +-
 src/gt_citation.cpp        |  750 ++++++++++++++++++++++++++++++--------------
 src/gt_citation.h          |   36 +-
 src/gt_wkt_srs.cpp         |  362 ++++++++++++++-------
 src/spatialreference.cpp   |   35 ++
 12 files changed, 1025 insertions(+), 465 deletions(-)
diffs (truncated from 2138 to 300 lines):
diff -r 5cd75fb456fa -r b9d8c358259a AUTHORS
--- a/AUTHORS	Mon Feb 28 10:17:21 2011 -0600
+++ b/AUTHORS	Thu Mar 24 08:23:22 2011 -0700
@@ -14,4 +14,4 @@
 warmerdam at pobox.com
 Michael P. Gerlek
-mpg at flaxen.com
+mpg at flaxen.com
diff -r 5cd75fb456fa -r b9d8c358259a apps/las2oci.cpp
--- a/apps/las2oci.cpp	Mon Feb 28 10:17:21 2011 -0600
+++ b/apps/las2oci.cpp	Thu Mar 24 08:23:22 2011 -0700
@@ -385,7 +385,9 @@
                     bool bUse3d,
                     bool bInsertHeaderBlob,
                     std::string const& header_blob_column,
-                    std::vector<boost::uint8_t> const& header_data)
+                    std::vector<boost::uint8_t> const& header_data,
+                    std::string const& boundary_column,
+                    std::string const& bounary_wkt)
     ostringstream oss;
@@ -399,7 +401,8 @@
     std::string cloudColumnName_u = to_upper(cloudColumnName);
     std::string aux_columns_u = to_upper(aux_columns);
     std::string header_blob_column_u = to_upper(header_blob_column);
+    std::string boundary_column_u = to_upper(boundary_column);
     ostringstream columns;
     ostringstream values;
@@ -417,6 +420,11 @@
         values <<", :2";
+    if (!boundary_column_u.empty()){
+        columns << "," << header_blob_column_u;
+        values <<", SDO_GEOMETRY(:3, :4)";
     ostringstream s_srid;
     ostringstream s_gtype;
@@ -594,6 +602,8 @@
     ("base-table-name", po::value< string >()->default_value("HOBU"), "The table name in which to put the point cloud object.  This table must have a column of type SDO_PC, with the name to be specified with --cloud-column-name")
     ("base-table-aux-columns", po::value< string >(), "Quoted, comma-separated list of columns to add to the SQL that gets executed as part of the point cloud insertion into the base-table-name")
     ("base-table-aux-values", po::value< string >(), "Quoted, comma-separated list of values to add to the SQL that gets executed as part of the point cloud insertion into the base-table-name")
+    ("base-table-boundary-column", po::value< string >(), "A SDO_GEOMETRY column in which to insert a bounds into the SDO_PC entry")
+    ("base-table-boundary-wkt", po::value< string >(), "A file or string with OGC Geometry WKT to insert into base-table-boundary-column")
     ("cloud-column-name", po::value< string >()->default_value("CLOUD"), "The column name that contains the point cloud object in the base table")
     ("header-blob-column", po::value< string >(), "Blob column name in the base table in which to optionally insert the contents of the input file's header.")
     ("block-table-name", po::value< string >(), "The table name in which to put the block data.  This table must be of type SDO_PC.BLK_TABLE.  This table will be created using the filename of the input LAS file if not specified.  Use -d to delete the table if it already exists.")
@@ -647,6 +657,8 @@
     std::string base_table_name("HOBU");
     std::string block_table_name("");
     std::string header_blob_column("");
+    std::string base_table_boundary_column("");
+    std::string base_table_boundary_wkt("");
     std::string pre_sql("");
     std::string post_sql("");
@@ -789,6 +801,23 @@
             if (verbose)
                 std::cout << "Setting output point cloud column to: " << point_cloud_name << std::endl;
+        if (vm.count("header-blob-column"))
+            base_table_boundary_column = vm["base-table-boundary-column"].as< string >();
+            base_table_boundary_wkt = vm["base-table-boundary-wkt"].as< string >();
+            if (base_table_boundary_wkt.size() == 0)
+                std::cerr << "base-table-boundary-column specified, but no wkt given with base-table-boundary-wkt!\n";
+                return 1;
+            if (verbose)
+                std::cout << "Insertting boundary into column: " << base_table_boundary_column << std::endl;
             header_blob_column = vm["header-blob-column"].as< string >();
@@ -1165,7 +1194,9 @@
                         bUse3d,
                         bInsertHeaderBlob,
                         header_blob_column,
-                        header_data);
+                        header_data,
+                        base_table_boundary_column,
+                        base_table_boundary_wkt);
         if (!pre_block_sql.empty()) {
diff -r 5cd75fb456fa -r b9d8c358259a doc/development/wkt.txt
--- a/doc/development/wkt.txt	Mon Feb 28 10:17:21 2011 -0600
+++ b/doc/development/wkt.txt	Thu Mar 24 08:23:22 2011 -0700
@@ -131,7 +131,7 @@
 Softwares that currently write GeoTIFF VLR records into LAS files can continue
 to do so in LAS 1.4. It is acceptable to write *only* GeoTIFF VLR records into
-an LAS file, while softwares that choose to write OGC WKT VLRs should also
+an LAS file, while softwares that choose to write OGC WKT VLRs must also
 write GeoTIFF VLRs to promote backward compatibility. If a file is found to
 have both OGC WKT and GeoTIFF VLRs, the OGC WKT description, which is more
 expressive, should be preferred if possible.
diff -r 5cd75fb456fa -r b9d8c358259a doc/download.txt
--- a/doc/download.txt	Mon Feb 28 10:17:21 2011 -0600
+++ b/doc/download.txt	Thu Mar 24 08:23:22 2011 -0700
@@ -8,7 +8,7 @@
 Current Release(s)
-* **2010-02-01**
+* **2011-02-01**
   - `libLAS-1.6.0-src.tar.gz  <http://download.osgeo.org/liblas/libLAS-1.6.0.tar.gz>`__
     `(md5) <http://download.osgeo.org/liblas/libLAS-1.6.0.tar.gz.md5>`__
@@ -39,7 +39,7 @@
 Past Releases
-* **2010-1-7**
+* **2011-1-7**
   - `libLAS-1.6.0b4-src.tar.gz  <http://download.osgeo.org/liblas/libLAS-1.6.0b4.tar.gz>`__
     `(md5) <http://download.osgeo.org/liblas/libLAS-1.6.0b4.tar.gz.md5>`__
diff -r 5cd75fb456fa -r b9d8c358259a include/liblas/bounds.hpp
--- a/include/liblas/bounds.hpp	Mon Feb 28 10:17:21 2011 -0600
+++ b/include/liblas/bounds.hpp	Thu Mar 24 08:23:22 2011 -0700
@@ -114,7 +114,7 @@
     bool overlaps(Range const& r) const
-        return minimum <= r.maximum && maximum >= r.minimum;
+        return minimum < r.maximum && maximum > r.minimum;
     bool contains(Range const& r) const
diff -r 5cd75fb456fa -r b9d8c358259a include/liblas/chipper.hpp
--- a/include/liblas/chipper.hpp	Mon Feb 28 10:17:21 2011 -0600
+++ b/include/liblas/chipper.hpp	Thu Mar 24 08:23:22 2011 -0700
@@ -61,6 +61,8 @@
         else
             return "NONE";
+    void SortByOIndex(boost::uint32_t left, boost::uint32_t center,
+        boost::uint32_t right);
 class LAS_DLL Chipper;
@@ -74,32 +76,43 @@
     boost::uint32_t m_left;
     boost::uint32_t m_right;
     liblas::Bounds<double> m_bounds;
-    // double m_xmin;
-    // double m_ymin;
-    // double m_xmax;
-    // double m_ymax;
 public:
     std::vector<boost::uint32_t> GetIDs() const;
-    liblas::Bounds<double> const& GetBounds() const {return m_bounds;}
-    void SetBounds(liblas::Bounds<double> const& bounds) {m_bounds = bounds;}
-    // double GetXmin() const
-    //     { return m_xmin; }
-    // double GetYmin() const
-    //     { return m_ymin; }
-    // double GetXmax() const
-    //     { return m_xmax; }
-    // double GetYmax() const
-    //     { return m_ymax; }
+    Bounds<double> const& GetBounds() const
+        {return m_bounds;}
+    void SetBounds(liblas::Bounds<double> const& bounds)
+        {m_bounds = bounds;}
+// Options that can be used to modify the behavior of the chipper.
+class LAS_DLL Options
+public:
+    Options() : m_threshold( 1000 ), m_use_sort( false ),
+       m_use_maps( false )
+    // Maximum number of pointer per output block.
+    boost::uint32_t m_threshold;
+    // If true, use sorting instead of copying to reduce memory.
+    bool m_use_sort;
+    // If true, use memory mapped files instead of main memory
+    // (not currently impelemented).
+    bool m_use_maps;
+    // Directory to hold map files.
+    std::string m_map_dir;
 public:
+    Chipper(Reader *reader, Options *options );
     Chipper(Reader *reader, boost::uint32_t max_partition_size) :
-        m_reader(reader), m_threshold(max_partition_size),
-        m_xvec(DIR_X), m_yvec(DIR_Y), m_spare(DIR_NONE)
+        m_reader(reader), m_xvec(DIR_X), m_yvec(DIR_Y), m_spare(DIR_NONE)
+        m_options.m_threshold = max_partition_size;
     void Chip();
     std::vector<Block>::size_type GetBlockCount()
@@ -108,25 +121,28 @@
         { return m_blocks[i]; }
 private:
-    void Load(RefList& xvec, RefList& yvec, RefList& spare);
+    void Allocate();
+    void Load();
     void Partition(boost::uint32_t size);
     void Split(RefList& xvec, RefList& yvec, RefList& spare);
     void DecideSplit(RefList& v1, RefList& v2, RefList& spare,
         boost::uint32_t left, boost::uint32_t right);
+    void RearrangeNarrow(RefList& wide, RefList& narrow, RefList& spare,
+        boost::uint32_t left, boost::uint32_t center, boost::uint32_t right);
     void Split(RefList& wide, RefList& narrow, RefList& spare,
     void FinalSplit(RefList& wide, RefList& narrow,
         boost::uint32_t pleft, boost::uint32_t pcenter);
     void Emit(RefList& wide, boost::uint32_t widemin, boost::uint32_t widemax,
-        RefList& narrow, boost::uint32_t narrowmin, boost::uint32_t narrowmax );
+        RefList& narrow, boost::uint32_t narrowmin, boost::uint32_t narrowmax);
     Reader *m_reader;
-    boost::uint32_t m_threshold;
     std::vector<Block> m_blocks;
     std::vector<boost::uint32_t> m_partitions;
     RefList m_xvec;
     RefList m_yvec;
     RefList m_spare;
+    Options m_options;
 } // namespace chipper
diff -r 5cd75fb456fa -r b9d8c358259a src/chipper.cpp
--- a/src/chipper.cpp	Mon Feb 28 10:17:21 2011 -0600
+++ b/src/chipper.cpp	Thu Mar 24 08:23:22 2011 -0700
@@ -42,6 +42,7 @@
 // boost
 #include <boost/cstdint.hpp>
 // std
+#include <algorithm>
 #include <cmath>
 using namespace std;
@@ -78,6 +79,39 @@
 namespace liblas { namespace chipper {
+class OIndexSorter
+public:
+    OIndexSorter(boost::uint32_t center) : m_center(center)
+    bool operator()(const PtRef& p1, const PtRef& p2)
+        if ( p1.m_oindex < m_center && p2.m_oindex >= m_center )
+            return true;
+        if ( p1.m_oindex >= m_center && p2.m_oindex < m_center )
+            return false;
+        return p1.m_pos < p2.m_pos;
+private:
+    boost::uint32_t m_center;
+void RefList::SortByOIndex(boost::uint32_t left, boost::uint32_t center,
+    OIndexSorter comparator(center);
+    vector<PtRef>::iterator li = m_vec.begin() + left;
+    vector<PtRef>::iterator ri = m_vec.begin() + right + 1;
+    sort(li, ri, comparator);
 vector<boost::uint32_t> Block::GetIDs() const
     vector<boost::uint32_t> ids;
@@ -87,65 +121,91 @@
More information about the Liblas-commits mailing list
