[Liblas-commits] hg-main-tree: BlockIterator scaffolding
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Mar 25 15:58:19 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/3733f45c647c
changeset: 471:3733f45c647c
user:      Howard Butler <hobu.inc at gmail.com>
date:      Fri Mar 25 14:56:40 2011 -0500
description:
Subject: hg-main-tree: merge
details:   http://hg.libpc.orghg-main-tree/rev/65fe5562bd8e
changeset: 472:65fe5562bd8e
date:      Fri Mar 25 14:58:05 2011 -0500
description:
merge
diffstat:
 include/libpc/Stage.hpp                       |   2 +
 include/libpc/Utils.hpp                       |   7 +++--
 include/libpc/filters/ChipperIterator.hpp     |  27 ++++++++++++-------------
 include/libpc/filters/ColorFilterIterator.hpp |   5 +---
 src/FilterIterator.cpp                        |  28 +++++++++++++++++++++++++++
 src/Iterator.cpp                              |  20 +++++++++++++++++++
 src/filters/ChipperIterator.cpp               |  13 +++++------
 test/unit/UtilsTest.cpp                       |  11 ++++++++++
 8 files changed, 85 insertions(+), 28 deletions(-)
diffs (213 lines):
diff -r 5f62edc05de5 -r 65fe5562bd8e include/libpc/Stage.hpp
--- a/include/libpc/Stage.hpp	Fri Mar 25 13:58:59 2011 -0500
+++ b/include/libpc/Stage.hpp	Fri Mar 25 14:58:05 2011 -0500
@@ -47,6 +47,7 @@
 class Iterator;
 class SequentialIterator;
 class RandomIterator;
+class BlockIterator;
 // every stage owns its own header, they are not shared
 class LIBPC_DLL Stage
@@ -73,6 +74,7 @@
     virtual bool supportsRandomIterator() const { return false; }
     virtual SequentialIterator* createSequentialIterator() const { return NULL; }
     virtual RandomIterator* createRandomIterator() const  { return NULL; }
+    virtual BlockIterator* createBlockIterator() const  { return NULL; }
 protected:
     void setHeader(Header*); // stage takes ownership
diff -r 5f62edc05de5 -r 65fe5562bd8e include/libpc/Utils.hpp
--- a/include/libpc/Utils.hpp	Fri Mar 25 13:58:59 2011 -0500
+++ b/include/libpc/Utils.hpp	Fri Mar 25 14:58:05 2011 -0500
@@ -62,13 +62,14 @@
     // compares two values to within a given tolerance
-    // BUG: need to disallow T to be an unsigned type
+    // the value |tolerance| is compared to |actual - expected|
     template<class T>
     static bool compare_approx(const T& actual, const T& expected, const T& tolerance)
-        const T diff = actual - expected;
+        const double diff = std::abs((double)actual - (double)expected);
+        const double delta = std::abs((double)tolerance);
-        if ( !((diff <= tolerance) && (diff >= -tolerance )) )
+        if (diff > delta)
             return false;
diff -r 5f62edc05de5 -r 65fe5562bd8e include/libpc/filters/ChipperIterator.hpp
--- a/include/libpc/filters/ChipperIterator.hpp	Fri Mar 25 13:58:59 2011 -0500
+++ b/include/libpc/filters/ChipperIterator.hpp	Fri Mar 25 14:58:05 2011 -0500
@@ -38,27 +38,26 @@
 #include <libpc/libpc.hpp>
 #include <libpc/FilterIterator.hpp>
+#include <libpc/filters/Chipper.hpp>
 namespace libpc {
 namespace filters {
-class Chipper;
-// class ChipperBlockIterator : public libpc::FilterBlockIterator
-// public:
-//     ChipperBlockIterator(const Chipper& filter);
-// private:
-//     boost::uint64_t skipImpl(boost::uint64_t);
-//     boost::uint32_t readImpl(PointBuffer&);
-//     bool atEndImpl() const;
-//     const Chipper& m_chipper;
+class ChipperBlockIterator : public libpc::FilterBlockIterator
+public:
+    ChipperBlockIterator(const Chipper& filter);
+private:
+    // boost::uint64_t skipImpl(boost::uint64_t);
+    // boost::uint32_t readImpl(PointBuffer&);
+    // bool atEndImpl() const;
+    const Chipper& m_chipper;
 } } // namespaces
diff -r 5f62edc05de5 -r 65fe5562bd8e include/libpc/filters/ColorFilterIterator.hpp
--- a/include/libpc/filters/ColorFilterIterator.hpp	Fri Mar 25 13:58:59 2011 -0500
+++ b/include/libpc/filters/ColorFilterIterator.hpp	Fri Mar 25 14:58:05 2011 -0500
@@ -36,15 +36,12 @@
 #define INCLUDED_FILTERS_COLORFILTERITERATOR_HPP
-//#include <boost/cstdint.hpp>
-//#include <libpc/export.hpp>
-//#include <libpc/Filter.hpp>
+#include <libpc/filters/ColorFilter.hpp>
 namespace libpc { namespace filters {
-class ColorFilter;
 class ColorFilterSequentialIterator : public libpc::FilterSequentialIterator
diff -r 5f62edc05de5 -r 65fe5562bd8e src/FilterIterator.cpp
--- a/src/FilterIterator.cpp	Fri Mar 25 13:58:59 2011 -0500
+++ b/src/FilterIterator.cpp	Fri Mar 25 14:58:05 2011 -0500
@@ -97,5 +97,33 @@
     return *m_prevIterator;
+FilterBlockIterator::FilterBlockIterator(const Filter& filter)
+    : BlockIterator(filter)
+    , m_filter(filter)
+    , m_prevIterator(NULL)
+    m_prevIterator = m_filter.getPrevStage().createBlockIterator();
+    return;
+FilterBlockIterator::~FilterBlockIterator()
+    delete m_prevIterator;
+BlockIterator& FilterBlockIterator::getPrevIterator()
+    return *m_prevIterator;
+const BlockIterator& FilterBlockIterator::getPrevIterator() const
 } // namespace libpc
diff -r 5f62edc05de5 -r 65fe5562bd8e src/Iterator.cpp
--- a/src/Iterator.cpp	Fri Mar 25 13:58:59 2011 -0500
+++ b/src/Iterator.cpp	Fri Mar 25 14:58:05 2011 -0500
@@ -190,4 +190,24 @@
+// BlockIterator
+BlockIterator::BlockIterator(const Stage& stage)
+    : Iterator(stage)
+    return;
+BlockIterator::~BlockIterator()
+    return;
diff -r 5f62edc05de5 -r 65fe5562bd8e src/filters/ChipperIterator.cpp
--- a/src/filters/ChipperIterator.cpp	Fri Mar 25 13:58:59 2011 -0500
+++ b/src/filters/ChipperIterator.cpp	Fri Mar 25 14:58:05 2011 -0500
@@ -38,13 +38,12 @@
-// ChipperBlockIterator::ChipperBlockIterator(Chipper const& filter)
-//     : libpc::FilterBlockIterator(filter)
-//     , m_chipper(filter)
-//     return;
+ChipperBlockIterator::ChipperBlockIterator(Chipper const& filter)
+    : libpc::FilterBlockIterator(filter)
+    , m_chipper(filter)
+    return;
 // boost::uint64_t ChipperSequentialIterator::skipImpl(boost::uint64_t count)
diff -r 5f62edc05de5 -r 65fe5562bd8e test/unit/UtilsTest.cpp
--- a/test/unit/UtilsTest.cpp	Fri Mar 25 13:58:59 2011 -0500
+++ b/test/unit/UtilsTest.cpp	Fri Mar 25 14:58:05 2011 -0500
@@ -98,6 +98,17 @@
         ok = Utils::compare_approx<float>(1.001f, 1.0f, 0.1f);
         BOOST_CHECK(ok);
+        ok = Utils::compare_approx<unsigned int>(10, 12, 2);
+        BOOST_CHECK(ok);
+        ok = Utils::compare_approx<unsigned int>(10, 12, 3);
+        BOOST_CHECK(ok);
+        ok = Utils::compare_approx<unsigned int>(10, 12, 1);
+        BOOST_CHECK(!ok);
More information about the Liblas-commits mailing list
