[Liblas-commits] hg-main-tree: more oci reader scaffolding
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Mar 28 13:57:33 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/3bbf7cfb2d83
changeset: 479:3bbf7cfb2d83
user:      Howard Butler <hobu.inc at gmail.com>
date:      Mon Mar 28 12:57:26 2011 -0500
description:
diffstat:
 include/libpc/drivers/oci/Reader.hpp |   4 ++++
 src/drivers/oci/Reader.cpp           |  32 ++++++++++++++++++++++++++++++++
 src/drivers/oci/Writer.cpp           |   4 +++-
 src/drivers/oci/common.cpp           |   2 ++
 4 files changed, 41 insertions(+), 1 deletions(-)
diffs (109 lines):
diff -r d21db9f1cdc2 -r 3bbf7cfb2d83 include/libpc/drivers/oci/Reader.hpp
--- a/include/libpc/drivers/oci/Reader.hpp	Mon Mar 28 12:03:53 2011 -0500
+++ b/include/libpc/drivers/oci/Reader.hpp	Mon Mar 28 12:57:26 2011 -0500
@@ -38,6 +38,7 @@
 #include <libpc/libpc.hpp>
 #include <libpc/Stage.hpp>
+#include <libpc/drivers/oci/Common.hpp>
 namespace libpc { namespace driver { namespace oci {
@@ -72,8 +73,11 @@
     Reader(const Reader&); // not implemented
+    void Debug();
     Options& m_options;
+    Connection m_connection;
+    bool m_verbose;
 }}} // namespace libpc::driver::oci
diff -r d21db9f1cdc2 -r 3bbf7cfb2d83 src/drivers/oci/Reader.cpp
--- a/src/drivers/oci/Reader.cpp	Mon Mar 28 12:03:53 2011 -0500
+++ b/src/drivers/oci/Reader.cpp	Mon Mar 28 12:57:26 2011 -0500
@@ -37,6 +37,7 @@
 #include <libpc/exceptions.hpp>
+#include <iostream>
@@ -44,10 +45,41 @@
 Reader::Reader(Options& options)
     : libpc::Stage()
     , m_options(options)
+    , m_verbose(false)
+void Reader::Debug()
+    bool debug = m_options.IsDebug();
+    if (debug)
+        m_verbose = true;
+    CPLPopErrorHandler();
+    if (debug)
+        const char* gdal_debug = Utils::getenv("CPL_DEBUG");
+        if (gdal_debug == 0)
+            Utils::putenv("CPL_DEBUG=ON");
+        const char* gdal_debug2 = getenv("CPL_DEBUG");
+        std::cout << "Setting GDAL debug handler CPL_DEBUG=" << gdal_debug2 << std::endl;
+        CPLPushErrorHandler(OCIGDALDebugErrorHandler);
+    else
+        CPLPushErrorHandler(OCIGDALErrorHandler);
 const std::string& Reader::getName() const
diff -r d21db9f1cdc2 -r 3bbf7cfb2d83 src/drivers/oci/Writer.cpp
--- a/src/drivers/oci/Writer.cpp	Mon Mar 28 12:03:53 2011 -0500
+++ b/src/drivers/oci/Writer.cpp	Mon Mar 28 12:57:26 2011 -0500
@@ -47,7 +47,6 @@
 Writer::Writer(Stage& prevStage, Options& options)
     : libpc::Writer(prevStage)
     , m_stage(prevStage)
-    // , m_chipper(m_stage, options.GetPTree().get<boost::uint32_t>("capacity") )
     , m_verbose(false)
@@ -439,6 +438,9 @@
     std::string base_table_aux_columns = to_upper(tree.get<std::string>("base_table_aux_columns"));
     std::string base_table_aux_values = to_upper(tree.get<std::string>("base_table_aux_values"));
     std::string header_blob_column_name = to_upper(tree.get<std::string>("header_blob_column_name"));
+    std::string base_table_boundary_column = to_upper(tree.get<std::string>("base_table_boundary_column"));
+    std::string base_table_boundary_wkt = to_upper(tree.get<std::string>("base_table_boundary_wkt"));
     boost::uint32_t srid = tree.get<boost::uint32_t>("srid");
     boost::uint32_t precision = tree.get<boost::uint32_t>("precision");
     boost::uint32_t capacity = tree.get<boost::uint32_t>("capacity");
diff -r d21db9f1cdc2 -r 3bbf7cfb2d83 src/drivers/oci/common.cpp
--- a/src/drivers/oci/common.cpp	Mon Mar 28 12:03:53 2011 -0500
+++ b/src/drivers/oci/common.cpp	Mon Mar 28 12:57:26 2011 -0500
@@ -66,6 +66,8 @@
     m_tree.put("header_blob_column_name", std::string("header"));
     m_tree.put("base_table_aux_columns", std::string(""));
     m_tree.put("base_table_aux_values", std::string(""));
+    m_tree.put("base_table_boundary_column", std::string(""));
+    m_tree.put("base_table_boundary_wkt", std::string(""));
     m_tree.put("pre_block_sql", std::string(""));
     m_tree.put("pre_sql", std::string(""));
     m_tree.put("post_block_sql", std::string(""));
More information about the Liblas-commits mailing list
