[Liblas-commits] hg-main-tree: add support for ByteSwapper filter
liblas-commits at liblas.org liblas-commits at liblas.org
Thu May 26 14:16:03 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/f9ad104194ba
changeset: 745:f9ad104194ba
user:      Howard Butler <hobu.inc at gmail.com>
date:      Thu May 26 13:14:14 2011 -0500
description:
Subject: hg-main-tree: return the actual number of points swapped instead of the capacity
details:   http://hg.libpc.orghg-main-tree/rev/2b385d0bc13d
changeset: 746:2b385d0bc13d
date:      Thu May 26 13:14:53 2011 -0500
description:
Subject: hg-main-tree: decrufting
details:   http://hg.libpc.orghg-main-tree/rev/3977b0274350
changeset: 747:3977b0274350
date:      Thu May 26 13:15:17 2011 -0500
description:
decrufting
Subject: hg-main-tree: start reworking to be able to use the ByteSwapper filter
details:   http://hg.libpc.orghg-main-tree/rev/b537b4c8ab21
changeset: 748:b537b4c8ab21
date:      Thu May 26 13:15:52 2011 -0500
description:
diffstat:
 apps/pc2pc.cpp                         |  14 +++++-
 include/libpc/drivers/oci/Writer.hpp   |   4 +-
 src/drivers/oci/Writer.cpp             |  27 ++++++++----
 src/filters/ByteSwapFilter.cpp         |   4 +-
 src/filters/ByteSwapFilterIterator.cpp |   3 +-
 src/filters/ChipperIterator.cpp        |  74 +---------------------------------
 6 files changed, 36 insertions(+), 90 deletions(-)
diffs (274 lines):
diff -r b7891eaf18fe -r b537b4c8ab21 apps/pc2pc.cpp
--- a/apps/pc2pc.cpp	Wed May 25 17:04:51 2011 -0500
+++ b/apps/pc2pc.cpp	Thu May 26 13:15:52 2011 -0500
@@ -27,6 +27,7 @@
 //#include <libpc/LasHeader.hpp>
 #include <libpc/drivers/las/Writer.hpp>
 #include <libpc/filters/CacheFilter.hpp>
+#include <libpc/filters/ByteSwapFilter.hpp>
 #include <libpc/drivers/liblas/Writer.hpp>
 #include <libpc/drivers/liblas/Reader.hpp>
@@ -150,9 +151,14 @@
         boost::uint32_t capacity = tree.get<boost::uint32_t>("capacity");
-        libpc::filters::CacheFilter cache(reader, 1, 1024);
+        libpc::filters::CacheFilter cache(reader, 1, capacity);
         libpc::filters::Chipper chipper(cache, capacity);
-        libpc::drivers::oci::Writer writer(chipper, options);
+        libpc::filters::ByteSwapFilter swapper(chipper);
+        libpc::drivers::oci::Writer writer(swapper, options);
+        // libpc::filters::CacheFilter cache(reader, 1, capacity);
+        // libpc::filters::Chipper chipper(cache, capacity);
+        // libpc::drivers::oci::Writer writer(chipper, options);
         writer.write(numPoints);
         boost::property_tree::ptree output_tree;
@@ -179,9 +185,11 @@
         const boost::uint64_t numPoints = reader.getNumPoints();
+        libpc::filters::ByteSwapFilter swapper(reader);
-        libpc::drivers::las::LasWriter writer(reader, *ofs);
+        libpc::drivers::las::LasWriter writer(swapper, *ofs);
         if (hasOption("a_srs"))
diff -r b7891eaf18fe -r b537b4c8ab21 include/libpc/drivers/oci/Writer.hpp
--- a/include/libpc/drivers/oci/Writer.hpp	Wed May 25 17:04:51 2011 -0500
+++ b/include/libpc/drivers/oci/Writer.hpp	Thu May 26 13:15:52 2011 -0500
@@ -97,8 +97,7 @@
     bool FillOraclePointBuffer(PointBuffer const& buffer,
                              std::vector<boost::uint8_t>& point_data);
-    bool WriteBlock(PointBuffer const& buffer,
-                             std::vector<boost::uint8_t>& point_data);
+    bool WriteBlock(PointBuffer const& buffer);
     void SetOrdinates(Statement statement,
                       OCIArray* ordinates,
@@ -110,6 +109,7 @@
     bool isDebug() const;
     bool is3d() const;
     bool isSolid() const;
+    // PointBuffer& ConstructBuffer(const PointBuffer& input) const;
     Stage& m_stage;
diff -r b7891eaf18fe -r b537b4c8ab21 src/drivers/oci/Writer.cpp
--- a/src/drivers/oci/Writer.cpp	Wed May 25 17:04:51 2011 -0500
+++ b/src/drivers/oci/Writer.cpp	Thu May 26 13:15:52 2011 -0500
@@ -1150,6 +1150,7 @@
                           libpc::Bounds<double> const& extent)
+    std::cout << extent << std::endl;
     statement->AddElement(ordinates, extent.getMinimum(0));
     statement->AddElement(ordinates, extent.getMaximum(1));
     if (extent.dimensions().size() > 2)
@@ -1163,10 +1164,11 @@
-bool Writer::WriteBlock(PointBuffer const& buffer,
+bool Writer::WriteBlock(PointBuffer const& buffer)
+    boost::uint8_t* point_data = buffer.getData(0);
     boost::property_tree::ptree&  tree = m_options.GetPTree();
     std::string block_table_name = to_upper(tree.get<std::string>("block_table_name"));
@@ -1181,8 +1183,9 @@
     // Pluck the block id out of the first point in the buffer
     libpc::Schema const& schema = buffer.getSchema();
     const int indexBlockId = schema.getDimensionIndex(Dimension::Field_User2, Dimension::Int32);
-    long block_id  = buffer.getField<boost::int32_t>(0, indexBlockId);
+    boost::int32_t block_id  = buffer.getField<boost::int32_t>(0, indexBlockId);
+    SWAP_ENDIANNESS(block_id); //We've already swapped these data, but we need to write a real number here.
     std::ostringstream oss;
     std::ostringstream partition;
@@ -1227,6 +1230,8 @@
     long* p_num_points = (long*) malloc (1 * sizeof(long));
     p_num_points[0] = (long)buffer.getNumPoints();
+    std::cout << "point count on write: " << buffer.getNumPoints() << std::endl;
     // :1
     statement->Bind( p_pc_id );
@@ -1245,7 +1250,7 @@
     // bool gotdata = GetResultData(result, reader, data, 3);
     // if (! gotdata) throw std::runtime_error("unable to fetch point data byte array");
-    statement->Bind((char*)&(point_data[0]),(long)point_data.size());
+    statement->Bind((char*)&(point_data[0]),(long)buffer.getSchemaLayout().getByteSize());
     // :5
     long* p_gtype = (long*) malloc (1 * sizeof(long));
@@ -1317,10 +1322,14 @@
 boost::uint32_t Writer::writeBuffer(const PointBuffer& buffer)
     boost::uint32_t numPoints = buffer.getNumPoints();
-    std::vector<boost::uint8_t> oracle_buffer;
-    FillOraclePointBuffer(buffer, oracle_buffer);
-    WriteBlock(buffer, oracle_buffer);
+    std::cout << buffer.getSchemaLayout().getSchema();
+    // std::vector<boost::uint8_t> oracle_array;
+    // boost::uint8_t* raw_data = buffer.getData(0)
+    // PointBuffer& output_buffer = ConstructBuffer(buffer)
+    // FillOraclePointBuffer(output_buffer, oracle_array);
+    WriteBlock(buffer);
     return numPoints;
diff -r b7891eaf18fe -r b537b4c8ab21 src/filters/ByteSwapFilter.cpp
--- a/src/filters/ByteSwapFilter.cpp	Wed May 25 17:04:51 2011 -0500
+++ b/src/filters/ByteSwapFilter.cpp	Thu May 26 13:15:52 2011 -0500
@@ -72,7 +72,9 @@
     libpc::Schema::Dimensions const& dstDims = dstSchema.getDimensions();
+    dstData.setSpatialBounds(srcData.getSpatialBounds());
     dstData.copyPointsFast(0, 0, srcData, srcData.getNumPoints());
     dstData.setNumPoints(srcData.getNumPoints());
     for (boost::uint32_t i = 0; i != dstData.getNumPoints(); ++i)
@@ -136,7 +138,7 @@
     //  assert(dstIndex <= dstData.getCapacity());
-    dstData.setNumPoints(dstData.getCapacity());
+    // dstData.setNumPoints(dstData.getCapacity());
     return dstData.getNumPoints();
diff -r b7891eaf18fe -r b537b4c8ab21 src/filters/ByteSwapFilterIterator.cpp
--- a/src/filters/ByteSwapFilterIterator.cpp	Wed May 25 17:04:51 2011 -0500
+++ b/src/filters/ByteSwapFilterIterator.cpp	Thu May 26 13:15:52 2011 -0500
@@ -85,9 +85,8 @@
     const boost::uint32_t numPointsAchieved = dstData.getNumPoints();
-    return dstData.getCapacity();
+    return numPointsAchieved;
diff -r b7891eaf18fe -r b537b4c8ab21 src/filters/ChipperIterator.cpp
--- a/src/filters/ChipperIterator.cpp	Wed May 25 17:04:51 2011 -0500
+++ b/src/filters/ChipperIterator.cpp	Thu May 26 13:15:52 2011 -0500
@@ -56,9 +56,6 @@
 boost::uint32_t ChipperSequentialIterator::readImpl(PointBuffer& buffer)
-    // The client has asked us for dstData.getCapacity() points.
-    // We will read from our previous stage until we get that amount (or
-    // until the previous stage runs out of points).
     if (m_currentBlockId == m_chipper.GetBlockCount())
         return 0; // we're done.
@@ -76,16 +73,13 @@
         throw libpc_error("Buffer not large enough to hold block!");
     block.GetBuffer(m_chipper.getPrevStage(), buffer, m_currentBlockId);
-    // FIXME: Set the PointBuffer's Bounds
     buffer.setSpatialBounds(block.GetBounds());
     m_currentBlockId++;
     return numPointsThisBlock;
 bool ChipperSequentialIterator::atEndImpl() const
     // we don't have a fixed point point --
@@ -94,70 +88,4 @@
     return iter.atEnd();
-// boost::uint64_t ChipperSequentialIterator::skipImpl(boost::uint64_t count)
-//     getPrevIterator().skip(count);
-//     return count;
-// bool ChipperSequentialIterator::atEndImpl() const
-//     return getPrevIterator().atEnd();
-// boost::uint32_t ChipperSequentialIterator::readImpl(PointBuffer& data)
-//     const boost::uint32_t numRead = getPrevIterator().read(data);
-//     // const boost::uint32_t cacheBlockSize = m_filter.getCacheBlockSize();
-//     // const boost::uint64_t currentPointIndex = getIndex();
-//     // // for now, we only read from the cache if they are asking for one point
-//     // // (this avoids the problem of an N-point request needing more than one
-//     // // cached block to satisfy it)
-//     // if (data.getCapacity() != 1)
-//     //     const boost::uint32_t numRead = getPrevIterator().read(data);
-//     //     // if they asked for a full block and we got a full block,
-//     //     // and the block we got is properly aligned and not already cached,
-//     //     // then let's cache it!
-//     //     const bool isCacheable = (data.getCapacity() == cacheBlockSize) &&
-//     //                              (numRead == cacheBlockSize) &&
-//     //                              (currentPointIndex % cacheBlockSize == 0);
-//     //     if (isCacheable && (m_filter.lookupInCache(currentPointIndex) == NULL))
-//     //         m_filter.addToCache(currentPointIndex, data);
-//     //     m_filter.updateStats(numRead, data.getCapacity());
-//     //     return numRead;
-//     // // they asked for just one point -- first, check Mister Cache
-//     // const PointBuffer* block = m_filter.lookupInCache(currentPointIndex);
-//     // if (block != NULL)
-//     //     // A hit! A palpable hit!
-//     //     data.copyPointFast(0,  currentPointIndex % cacheBlockSize, *block);
-//     //     m_filter.updateStats(0, 1);
-//     //     return 1;
-//     // // Not in the cache, so do a normal read :-(
-//     // m_filter.updateStats(numRead, numRead);
-//     return numRead;
 } } // namespaces
More information about the Liblas-commits mailing list
