[Liblas-commits] [libLAS/libLAS] 2eca80: Fixed point_source_id property arguments.
GitHub noreply at github.com
Mon Dec 23 11:41:31 PST 2013
  Branch: refs/heads/master
  Home:   https://github.com/libLAS/libLAS
  Commit: 2eca80be20e4a476a2352e5c3e980e19c913648a
      https://github.com/libLAS/libLAS/commit/2eca80be20e4a476a2352e5c3e980e19c913648a
  Author: rickhg12hs <rickhg12hs at gmail.com>
  Date:   2013-11-21 (Thu, 21 Nov 2013)
  Changed paths:
    M python/liblas/point.py
  Log Message:
  Commit: 1b19da8cb6f64bc758394bbe82f6f12c862c1b64
      https://github.com/libLAS/libLAS/commit/1b19da8cb6f64bc758394bbe82f6f12c862c1b64
  Changed paths:
  Log Message:
  Fixed set_point_source_id function call.
  Commit: 490c7e421effdd6581b45032fc75ce9d4448fb1f
      https://github.com/libLAS/libLAS/commit/490c7e421effdd6581b45032fc75ce9d4448fb1f
  Changed paths:
    M python/liblas/core.py
  Log Message:
  Changed las.LASPoint_{Set,Get}PointSourceId.restype assignment to ctypes.c_uint16 so that it matches boost::unit16_t in src/point.cpp
  Commit: d9d1fed5682073980b4826f55f445a550345a46a
      https://github.com/libLAS/libLAS/commit/d9d1fed5682073980b4826f55f445a550345a46a
  Author: Howard Butler <howard at hobu.co>
  Date:   2013-12-23 (Mon, 23 Dec 2013)
  Log Message:
  Merge pull request #28 from rickhg12hs/master
Fixed point_source_id issues in python/liblas/{point.py,core.py}
Compare: https://github.com/libLAS/libLAS/compare/196ba43ace04...d9d1fed56820
More information about the Liblas-commits mailing list
