[Liblas-commits] [libLAS/libLAS] b09f06: cmake: install liblas-config.cmake into lib/cmake
GitHub noreply at github.com
Wed Oct 31 09:14:10 PDT 2018
  Branch: refs/heads/master
  Home:   https://github.com/libLAS/libLAS
  Commit: b09f063689f4e259cd95ce61737067945e2fdeeb
      https://github.com/libLAS/libLAS/commit/b09f063689f4e259cd95ce61737067945e2fdeeb
  Author: Ben Boeckel <ben.boeckel at kitware.com>
  Date:   2018-10-31 (Wed, 31 Oct 2018)
  Changed paths:
    M cmake/CMakeLists.txt
  Log Message:
This is required because liblas-config.cmake refers to arch-specific
locations. Without this, 32bit liblas-config.cmake conflicts with 64bit
liblas-config.cmake on multi-arch distributions.
  Commit: 1d006edbe01b60971c7c479ac1a4f85864b09628
      https://github.com/libLAS/libLAS/commit/1d006edbe01b60971c7c479ac1a4f85864b09628
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
  Log Message:
  Merge pull request #150 from mathstuf/cmake-into-libdir
Compare: https://github.com/libLAS/libLAS/compare/7bbcb10a46ff...1d006edbe01b
      **NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
      Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the Liblas-commits mailing list
