[Liblas-devel] ReadPointAt bug
Mateusz Loskot mateusz at loskot.net
Tue Apr 22 10:19:32 EDT 2008
Howard Butler wrote:
> I'm not sure, and we would need a spec hound to verify, but I think that
> the file in question is not following the spec.  It *says* it is 1.0,
> but it has a 28 byte record length (this would imply a 1.1 version file,
> right)?  So, who are we to believe?  The file version, like we were
> doing, or the record length, which in this case produces the correct
> results?
> Mateusz, do you have anything to add on this?
There are two identifiers that control LAS file processing:
1. LAS File Version (1.0 or 1.1)
2. Point Format ID (0 or 1)
So, following combinations are valid:
- point record size is 20 bytes
1.0 & 0
1.1 & 0
- point record size is 28 bytes
1.0 & 1
1.1 & 1
The libLAS strongly depends on what's written to the header, so this
information must be as stated above, otherwise we are dealing with
invalid LAS file.
If the information in header is correct, then we likely are having a bug.
Which one is true?
Greetings
Mateusz Loskot
http://mateusz.loskot.net
More information about the Liblas-devel mailing list
