[Liblas-devel] Throwing out_of_range exceptions on read
Mateusz Loskot mateusz at loskot.net
Mon Apr 28 20:55:12 EDT 2008
Howard Butler wrote:
>>> Mateusz,
>>> Mark in Florida has some 1.1 LAS files that have points with Scan
>>> Angle Ranks that are outside the -90/90 range that the specification
>>> says.
>> Hobu,
>> Seems, Mark's file does not follow the LAS specification.
>> Is that possible?
> Yes, I agree.  I think the file is out of spec.
OK.
>> If yes, then I think it would be worth to know what's the generator of
>> such file and provide appropriate warning/comment in libLAS FAQ.
> The offending software writes 1.1 files with the following:
>   Project ID/GUID:           '00000000-0000-0000-0000-000000000776'
>   System Identifier:         'NIIRS10'
>   Generating Software:       'LIDAR1 tiled'
I found that NIIRS10 means LIDAR 1 CuePac software by GeoCue.
>>> I just commented out the check for now:
>>> http://liblas.org/browser/trunk/src/laspoint.cpp#L113
>> OK
>>> This begs the question, what do we do for reading invalid input?
>> I would prefer to keep validating it.
> I don't know that we can keep validating it *where* we validate
> currently -- in the getter/setter methods of LASPoint.
Yes, sounds reasonable.
> Maybe we could have something like
> -- ReadNextPoint(bool validate)
> -- if (validate) {LASPoint::validate();}
Good idea.
> and have LASPoint::validate toss an exception.  This way we can do it on
> write as well.  I'm not sure out_of_range is the best exception to throw
> either.
It probably isn't, but I'd not worry to much.
I'm going to introduce some dedicated exceptions this week/weekend,
as planned here http://liblas.org/ticket/12
> Some things that might be good candidates for validate():
>  - Invalid time values
>  - Scan angle rank
>  - flight edge not being 1 or 0
>  - invalid classifcation values
>  - invalid scan direction
Seems like we could base on rules described in the specification:
if the spec defines valid value/range of a data, then let's check it.
>>> Scan angle doesn't really mean too much, so for this case, following
>>> the spec exactly isn't going to be a deal, especially if there are
>>> other writers out there who aren't following. But for other items,
>>> especially the flags attributes, this is a big deal.
>> Your suggestion sounds reasonable to me. However, I'd like to propose
>> some modifications (below) :-)
>>> Any ideas on a reasonable tact to take?  Liberal in what we read and
>>> strict in what we write?
>> 1. The ASPRS LAS format is suppose to be a data exchange format,
>> so we always must [sic] write in strict mode. IMHO, if LAS writers are
>> very  relaxed, then interoperability - a very principle of ASPRS LAS
>> format - will be on paper only.
> Such is the fallacy of all standards :)
I imagine, place the fallacy of my belief the World is ideal ;-)
> I think we should have LASWriter do validate() on write,
> and we should not allow folks to circumvent this with a flag.
Good idea. I support it.
> It adds a few checks and might cost some
> raw write performance, but it is just pushing the existing test that
> lives in the LASPoint methods around so it isn't a net gain or loss in
> performance.
Yes.
>> 2. I'd vote for libLAS reading in semi-relaxed mode by default, what
>> actually you are suggesting above, but in strict mode on request (a
>> configuration setting, a program parameter, etc.).
> For read operations, I think we should have a flag that allows you to
> use relaxed reading, but we should default to validate() on read as
> well, IMO.
Good idea.
> For translation operations like las2las, this might mean
> throwing out points that aren't to spec, because write() isn't going to
> allow it.  I would have las2las provide summary in that instance.
Yes, plus some note in the manual should do the job well.
> The only way to get people to write files in spec are to tell them
> they're writing it out of spec :)
I think so too.
> Also, I would venture a guess that
> libLAS is the first LAS format library out there to really care about
> validating the parts of the base spec we implement.
I believe it scores :-)
>> 3. While reading LAS file in semi-relaxed, the library should always
>> print a warning to stdout.
> I have changed all of the utilities to emit text output to stderr
> because stdin/stdout can be used for regular file i/o for some of them.
Right. All diagnostics should go to stderr. BTW, when using C++ streams,
std::cerr and std::clog are best candidates. Then it's easy to redirect
these streams to file, for instance.
> IMO, the library shouldn't print error messages anywhere, and it should
> notify the application that there's an error or warning and let it
> decide what to do.  I already have stuff in the C API's error handling
> to be able to deal with this, I think.
OK, works for me.
> Anyone else with thoughts on this issue, please chime in.  I don't want
> to box folks in because a lot of times you don't control who's giving
> you LAS files to deal with.  On the other hand, I don't want to
> perpetuate crappy broken data either...
Personally, I like your idea.
If no new concepts will reach the list, I suggest to implement what
we've discussed already and push it to users. Nothing is fixed in
concrete, so we can improved the solution in future.
Greetings
Mateusz Loskot
http://mateusz.loskot.net
More information about the Liblas-devel mailing list
