[Liblas-devel] .net/mono bindings in c#
Howard Butler hobu.inc at gmail.com
Wed Aug 6 12:43:19 EDT 2008
On Aug 6, 2008, at 9:23 AM, Mateusz Loskot wrote:
> Martin Rodriguez wrote:
>> Hi all:
>> I am working in .net/mono bindings to liblas and i have something
>> like
>> 80% work done,
> Martin,
> Great news!
>> but i have several problems:
>> -          I have created a successful mingw compilation without use
>> CAPI module. This module use a macro _MSC_VER in the las_config.h
>> header
>> /* FIXME -  Ticket #23 */
>> #ifdef _MSC_VER
>> #define PACKAGE_VERSION "1.0.0b1"
>> #endif
>> -          CAPI use this macro only to return in a function.  I
>> believe
>> in liblas purposes we could do something like this:
>> -          defined(__CYGWIN__) || defined(__MINGW32__) ||
>> defined(_MSC_VER)
> Good point. Could you please report it as a Ticket [1] and attach
> proposed changes in all places you need?
> [1] http://liblas.org/
>> - C++ API compile and works fine, but I am worried because I see the
>> macro in some other headers like bin endian/little endian module.
> You mean the _MSC_VER macro used in there?
> If yes, so while reporting a ticket, pelase specify all places where
> you
> propose to change it.
>> -          Anyway I am using your DLL for .NET, but it would be great
>> for me work with my DLL. Besides Mingw binaries are very useful for
>> me
>> because almost all APIs I use in C/C++ are ready to mingw (gtk,gtkmm,
>> inscape, gimp, vala, ruby, etc, etc) . There many only 2 libraries
>> I use
>> for VS like Mysql and postgree, but mingw have a DLL converter tool
>> to
>> import them. .NET have the advantage to find entry point in mingw
>> and vc
>> DLL in the same way.
> Understood.
>> -          I am working in Setters and getters in c# and I see some
>> rare
>> things in the CAPI module.
>> LAS_DLL uint8_t LASHeader_GetDataFormatId(const LASHeaderH hHeader);
>> -          LAS_DLL LASError LASHeader_SetDataFormatId(const
>> LASHeaderH
>> hHeader, int value);
>> -          Why do you have a kind of data to c++ to the getter and
>> other
>> to the setter???. In c++ this is not a problem because the getters
>> and
>> setter are visible, but in .NET not (only in compiled code). I saw
>> like
>> 3 functions like that.
> You mean the uint8_t vs int ?
> Yes, it's incorrect and I believe it should be changed to uint8_t.
> Howard, do you have any objections about this fix?
Fixed http://liblas.org/ticket/64
Martin,
If you are interested in including this work as part of libLAS, I can
provide you with a svn login to allow you to commit it to the source
repository.  It is a little late in our release process, but we can
hold up the release to include this, as it doesn't directly affect the
base library and I think others would find it very useful.
Howard
More information about the Liblas-devel mailing list
