[Liblas-devel] .net/mono bindings in c#
Mateusz Loskot mateusz at loskot.net
Fri Aug 8 08:56:12 EDT 2008
Howard Butler wrote:
> On Aug 8, 2008, at 2:12 AM, Martin Rodriguez wrote:
>> Hi>
>>> I saw a Trac login on http://liblas.org under the name 'martin' and I
>>> assumed that is you.  Anyway, I have given you svn commit access, and
>>> I created a csharp directory in which you can layout and place your
>>> bindings.  I would suggest hanging out on #liblas on irc.freenode.net
>>> to catch Mateusz and I if you have any questions.
>> Yes, i am. Thank you
>> csharp directory not please. This is not a c# bindings else mono/.net
>> bindings.
> For GDAL and MapServer, we use csharp as the catch all name for the .net
> families of languages.  This is mostly because calling the directory
> ".NET" or anything similar is likely to cause problems (hidden directory
> on *nix using the literal .NET directory name -- calling a directory
> "net" is not very descriptive).
> I wouldn't be adverse to renaming the directory to "dotnet" if you wish,
> however...
I also vote for lower-case names.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
More information about the Liblas-devel mailing list
