[Liblas-devel] St9bad_alloc (3) from method LASReader_Create
Howard Butler hobu.inc at gmail.com
Sun Aug 17 00:15:24 EDT 2008
Rory,
I have fixed this problem.  http://liblas.org/ticket/68 It was a bug
in libLAS where I was using the wrong return type to describe the
length of the variable length record.  Merrick makes some VLRs that
are larger than the size of the number I was using to hold the length,
and when I turned around to allocate storage to save the VLR, I was
allocating a negative length :P
Thanks for the report.
Howard
On Aug 15, 2008, at 1:55 PM, Sutton, Rory J SAJ wrote:
> Howard
>   Merrick. Yes, they have egregeous numbers of VLRs. They are
> composed of pointers to blocks of point records, to enable their
> proprietary software, MARS, to be fast on LAS input. Your
> remove_extra_header option comes in handy. Does it make sense?
> Probably to Merrick. The rest of us just have to work around it.
> Rory Sutton
> 904-334-8373 (cell)
> ----- Original Message -----
> From: Howard Butler <hobu.inc at gmail.com>
> To: Sutton, Rory J SAJ
> Cc: liblas-devel at mail.hobu.net <liblas-devel at mail.hobu.net>; Holt,
> Paul R SAJ Contractor; Vogler, Dan SAJ Contractor
> Sent: Fri Aug 15 13:53:33 2008
> Subject: Re: [Liblas-devel] St9bad_alloc (3) from method
> LASReader_Create
> Rory,
> I have duplicated your findings, and I have an idea what might be
> going on, but I have a question about the file.  Do you know what
> software created them?  The problem is in the header reading code, and
> it is seeing that there are 390 Variable Length Header records in the
> file.  VLRs are used by LAS softwares to store application-specific
> stuff.  Does it make sense that this file would have so many of these
> records?
> Howard
> On Aug 15, 2008, at 11:51 AM, Sutton, Rory J SAJ wrote:
> > We have just taken delivery on literally thousands of lidar files in
> > LAS 1.1
> > format.  A few of these trigger something in lasinfo (and las2las)
> > that
> > results in the following:
> > Could not open file : St9bad_alloc (3) from method LASReader_Create
> > I'm seeing this on 64-bit linux and Windows XP (separate machines)
> > for those
> > few files that have this property.  I'm a rank amateur at this but a
> > trace in
> > DDD/GDB on linux seems to indicate the exception is being thrown at
> > the
> > Init() below, from lasreader.cpp.  A file that triggers this (at
> > least in my
> > environment) and one that doesn't, have been posted to
> > ftp://ftp.usace.army.mil/pub/saj/las .  I've got lots of RAM on both
> > Windows
> > and Linux.  Any clues would be appreciated.
> > |$Id: lasreader.cpp 813 2008-07-25 21:53:52Z mloskot $ |
> > #include <liblas/lasreader.hpp>
> > #include <liblas/detail/reader.hpp>
> > // std
> > #include <stdexcept>
> > #include <fstream>
> > #include <string>
> > #include <cstring> // std::memset
> > #include <cassert>
> > namespace liblas
> > LASReader::LASReader(std::istream& ifs) :
> >    m_pimpl(detail::ReaderFactory::Create(ifs))
> >    Init();
> > Liblas-devel mailing list
> > Liblas-devel at mail.hobu.net
> > http://mail.hobu.net/mailman/listinfo/liblas-devel
More information about the Liblas-devel mailing list
