[Liblas-devel] /GR vs /EHsc
Mateusz Łoskot mateusz at loskot.net
Wed Oct 8 15:49:47 EDT 2008
Howard Butler pisze:
> On Sep 26, 2008, at 2:17 PM, Mateusz Loskot wrote:
>> Folks,
>> I see we don't distinguish compilation flags for versions of Visual C++.
>> I think we should do the same what GDAL or GEOS does:
>> nmake -f makefile.vc MSVC_VER=XXX
>> where XXX is 1500, 1400, 1310, etc.
>> For example, Visual C++ 7.1 uses /GX option which was replaced with
>> /EHsc in later versions of the compiler.
> Mateusz,
> I am ambivalent about this.  Even though /GX was replaced, latter
> versions of the compiler respect it, correct?
Hobu,
Yes, /GX is equivalent to /EHsc
> The problem with MSVC_VER
> is the ease at which someone can forget to specify it as part of the
> compilation.  I don't like this particular approach of GDAL and
> MapServer.  It's too easy to forget.  If we had lots of switches that
> were version dependent, I could see a stronger need for it, but I don't
> think we should do it for a single switch that is indefinitely supported
> throughout the MSVC compiler chain.
OK, I agree with your reasoning.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
More information about the Liblas-devel mailing list
