[Liblas-devel] liblas problems
Martin Vales martinvales00 at gmail.com
Tue Oct 28 06:51:21 EDT 2008
Hi:
> I believe that using cached point is a compromise between memory management
> and performance. It doesn't prevent users from making their own copy of
> point object.
I totally agree, but i need change the .net API a little (I made a point
copy by default)  and add this information for the users:
liblas use a cached point for a compromise between memory management and
performance. It doesn't prevent users from making their own copy of point
object.
I hope nobody used the .NET API by now. for someone here is a problem a
change in the .NET API???
mateus do you know the differences between your vc++ compilation and the
hobu compilation?
Regards.
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> Charter Member of OSGeo, http://osgeo.org
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20081028/a0dde83e/attachment.html
More information about the Liblas-devel mailing list
