[Liblas-devel] liblas problems
Mateusz Loskot mateusz at loskot.net
Tue Oct 28 08:33:05 EDT 2008
Martin Vales pisze:
>> I believe that using cached point is a compromise between memory management
>> and performance. It doesn't prevent users from making their own copy of
>> point object.
> I totally agree, but i need change the .net API a little (I made a point
> copy by default)  and add this information for the users:
> liblas use a cached point for a compromise between memory management and
> performance. It doesn't prevent users from making their own copy of point
> object.
Cool!
> I hope nobody used the .NET API by now. for someone here is a problem a
> change in the .NET API???
I believe you can safely update the .NET bindings.
> mateus do you know the differences between your vc++ compilation and the
> hobu compilation?
I don't know, but the only differences I'd expect should be in
compilation/linking flags. So, I suggest to compare those flags
from nmake.opt file against flags in liblas_lib.vcproj and
liblas_c_dll.vcproj.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
More information about the Liblas-devel mailing list
