[Liblas-devel] PROJ4 / Georeference info?
Jason Woolard Jason.Woolard at noaa.gov
Fri Oct 31 13:02:02 EDT 2008
Thanks Howard. The problem is on my end. The strange thing is I can get
this to work on a different computer. I remembered I was never able to
get the win32 exe to properly install on my machine. No errors during
the install it just doesn't import liblas. Martin R. gave me a DLL he
made from a mingw compilation and I can get it to work by replacing
liblas1.dll with his dll. Otherwise I get this:
 >>> from liblas import file
  File "<pyshell#16>", line 1, in <module>
  File "C:\pythonxy\python\Lib\site-packages\liblas\__init__.py", line
1, in <module>
    from core import *
  File "C:\pythonxy\python\Lib\site-packages\liblas\core.py", line 112,
in <module>
    las = ctypes.CDLL(lib_name)
  File "C:\pythonxy\python\lib\ctypes\__init__.py", line 348, in __init__
    self._handle = _dlopen(self._name, mode)
WindowsError: [Error 127] The specified procedure could not be found
Everything had been working fine until now. I know it's a problem with
my pc because I have 1.0.0 successfully installed at home. I haven't
seen anyone else report this since 1.0.0 was released. Have you seen
this issue recently? The only difference I can think of is one machine
is XP home and one is XP Professional but that really shouldn't matter.
Howard Butler wrote:
> This works almost exactly for me...
>> >>> input = file.File('TO_core_last_clip.las')
>> >>> h = input.header
>> >>> h.proj4
>> >>> h.proj4 =  '+proj=utm +zone=17 +ellps=WGS84 +units=m'
>> >>> h.proj4
>> >>> output = file.File('junk.las',mode='w', header = h)
>> >>> output.header.proj4
>> >>> output.write(input.read(0))
>> >>> output.close()
>> >>> del output
>> >>> output = file.File('junk.las')
>> >>> output.header.proj4
>> '+proj=tmerc +lat_0=0.000000000 +lon_0=-81.000000000 +k=0.999600
>> +x_0=500000.000 +y_0=0.000 +ellps=WGS84 +units=m '
> The only thing I'm doing different is making sure to manually delete
> the reference to output when working in the interpreter to ensure that
> the file is actually flushed and not using 'header' as the name for my
> header that I'm writing to the file to ensure that I don't have a
> namespace collision or something.
> Other than that, is it possible our versions are out of sync?
> On Oct 30, 2008, at 2:25 PM, Jason Woolard wrote:
>> hi again,
>> Your example still returns an empty string for me:
>> >>> input = file.File('C:\\liblas_test\\debug.las')
>> >>> header = input.header
>> >>> header.proj4
>> >>> header.proj4 = '+proj=utm +zone=17 +ellps=WGS84 +units=m'
>> >>> header.proj4
>> >>> output =
>> file.File('C:\\liblas_test\\junk_srs.las',mode='w',header=header)
>> >>> output.header.proj4
>> >>> output.close()
>> >>> output = file.File('C:\\liblas_test\\junk_srs.las',mode='r')
>> >>> output.header.proj4
>> Am I maybe using Proj4 incorrectly? I'm just trying to add the
>> Projection/geoference info into the header where it doesn't exist.
>> Also, If I understood the posts from you and Mateusz it is necessary
>> to write something (even a zero record) if you are making any changes
>> to the input LAS file?
>> Thanks again,
>> Jason
>>> On Oct 29, 2008, at 10:27 PM, Jason Woolard wrote:
>>>> Thanks for the great work here. The library is working quite well.
>>>> I have another quick question though. Sorry if I'm missing
>>>> something obvious.
>>>> I'm trying to add projection and georeference info to LAS header
>>>> files that currently don't have any projection info. I was thinking
>>>> something like this would work:
>>>> >>> infile = liblas.file.File('C:\\liblas_test\\debug.las',mode='r')
>>>> >>> h = infile.header
>>>> >>> h.proj4 ='+proj=utm +zone=17 +ellps=WGS84 +units=m'
>>>> >>> h.proj4
>>>> >>> outfile =
>>>> liblas.file.File('C:\\liblas_test\\debug_junk.las',mode='w', header=h)
>>>> >>> outfile.header.proj4
>>>> >>> outfile.close()
>>>> >>> outfile =
>>>> liblas.file.File('C:\\liblas_test\\debug_junk.las',mode='r')
>>> You have to write a point to the file or it is not valid.  I guess
>>> we should update the wiki to reflect this...  I also wonder if maybe
>>> we should have the writer try to throw an exception when nPoints is
>>> 0...
>>>> >>> input = file.File('srs.las')
>>>> >>> header.proj4
>>>> '+proj=utm +zone=17 +ellps=WGS84 +units=m '
>>>> >>> output = file.File('junk_srs.las',mode='w',header=header)
>>>> >>> output.header.proj4
>>>> >>> output.write(input.read(0)) # read the first point and write it
>>>> to the file
>>>> >>> output.close()
>>>> >>> output = file.File('junk_srs.las',mode='r')
>>>> >>> output.header.proj4
More information about the Liblas-devel mailing list
