[Liblas-devel] PROJ4 / Georeference info?
Howard Butler hobu.inc at gmail.com
Fri Oct 31 16:58:17 EDT 2008
aha!
That's because you have an older libtiff.dll ahead of the one in c:
\python2x\DLLs in your PATH and it is being picked up.  Search for all
of your libtiff.dlls and check the dates on them.  The one that should
be used (make sure it is first on your PATH), is dated 9/1/2008
On Oct 31, 2008, at 3:49 PM, Jason Woolard wrote:
> Sure thing. I did get a dialog error running it at the Windows CMD.
> See attached.
> Could it possibly be conflicting with something?  I have FWTools
> installed but I removed everything else Python related .
> Howard Butler wrote:
>> On Oct 31, 2008, at 1:39 PM, Martin Vales wrote:
>>> This is the same error in .NET.
>>> The CAPI is not public for Dynamic loaders like Ctypes or p/invoke..
>> I have no trouble running the Python unittests under windows with
>> Python 2.4 or 2.5 and ctypes.  This is using ctypes and the
>> liblas1.dll that I have built and included in both the windows .zip
>> file *and* the PyPI libLAS bindings.  This dll was built with:
>> __declspec(dllexport)
>> declarations.
>> Jason,
>> Could you try running your script from a cmd.exe instead of in the
>> Python IDE.  Maybe a dialog will come up when ctypes tries to
>> access the dll and state which procedure it can't find.
>> Howard
> <libtiff_error.bmp>
More information about the Liblas-devel mailing list
