[Liblas-devel] Re: FOSS4G Presentation
Martin Rodriguez mrodriguez at stereocarto.com
Tue Sep 23 13:23:52 EDT 2008
Hi:
>> Now, iterators can have different faces:
>> - they can work just as pointers do
>> - they can work as a view concept - view as interms of SQL view
>> - they can extend elements accesssing with custom logic like filtering,
>> transformation, etc.
I didn´t know this.
>>  author likes events much. In some languages like Java and C#, where
Java don´t have native delegates/events. This is a concept new in c# and
after use in D.
> When working with iterators, you don't need to know number elements you
> are going to read. You just work with ranges of elements of a sequence.
Yes, like List or trees. You are right.
>> BOOST_FOREACH is cool and it simplifies sequence iterating much.
>> However, it's not anything different, just a syntactic sugar to make use
>> of iterators easier. But still, we need to provide access to LAS
>> reader/writer with iterators, iterators in terms of STL concept.
Yes but it´s useful for people. They avoid create the boilerplate.
In c# or in D you need add the backend to the class to have support to the
foreach the same to C++.
I don´t use boost but I saw it´s only a MACRO to STL very similar to the Qt
foreach using the moc preprocessor.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
More information about the Liblas-devel mailing list
