[Liblas-devel] Patch for utility.hpp for negative elevations
Erik Jacobsen jacobsen at powline.com
Thu Sep 25 11:32:47 EDT 2008
Hello All,
First, I would like to thank the developers for this excellent library.
It has been easy to use, particularly after the addition of makefile.vc.
I have been trying it with various data sets and have discovered what
appears to be a bug.  The data set in question contains points that are
below sea level (i.e. z values are negative).  After reading with
liblas, the z values are instead ~4 billion.  This was with 1.0.0b1, so
I downloaded trunk-r878 and duplicated the problem.  When stepping
through the code I discovered that the coordinates are being stored in a
uint32_t instead of an int32_t.  The LAS 1.1 specification for "POINT
DATA RECORD FORMAT 0" states that X, Y and Z are stored in "long" which
is defined to be a signed 4 byte quantity (page 6).  The following patch
solves the problem and produces sane results:
C:\dev\LAS\trunk\include\liblas\detail>"C:\Program Files
(x86)\GnuWin32\bin\diff.exe" util
ity.hpp C:\dev\las\utility.hpp
185,187c185,187
<     int32_t x;
<     int32_t y;
<     int32_t z;
 >     uint32_t x;
 >     uint32_t y;
 >     uint32_t z;
Please consider including it in the trunk.
Thank you,
Erik
Erik Jacobsen, Power Line Systems, Inc.
Email: jacobsen at powline.com
Phone: (608) 238-2171 x104
Fax:   (608) 238-9241
Web:   http://www.powline.com/
More information about the Liblas-devel mailing list
