[Liblas-devel] Classification improvements
Mateusz Loskot mateusz at loskot.net
Wed Apr 15 15:01:32 EDT 2009
Howard Butler wrote:
> On Apr 15, 2009, at 8:16 AM, Mateusz Loskot wrote:
>> Folks,
>> Handling classification is not as easy as it may seem. There are number
>> of elements like lookup table stored is variable-length record (LAS 1.0)
>> or defined in spec (LAS 1.1+) as well as tricky bitwise operations are
>> needed to access classification values for a point record. The purpose
>> of the ticket is to submit and discuss proposal of improvements in this
>> area.
>> Basically, the idea is to extract all types, enumerations and operations
>> directly related to classification handling as a class type. Then,
>> LASPoint::GetClassification/SetClassification provide access to object
>> which can be used to manage (read, write) all properties of
>> classification.
>> I'm going to implement all relevant parts of this enhancement.
>> First, I'd like to know your comments about this idea.
> An emphatic +1, because I was going to eventually have to do it
> otherwise :)
Great. I'm on it [1] committing soon.
[1] http://liblas.org/ticket/131
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
More information about the Liblas-devel mailing list
