[Liblas-devel] Indexing for point clouds
Volker Wichmann wichmann at laserdata.at
Wed Apr 22 05:45:36 EDT 2009
I've no experience with either spatialindex nor GML LidarK, but maybe
you can find some hints on
http://research.graphicon.ru/3d-point-data-processing/gml-lidark-library-6.html
There's some discussion on pro/cons of various indexing approaches.
Volker
Howard Butler wrote:
> I have been investigating and prototyping linking spatialindex with
> libLAS, but I have a few questions of the practicality of this
> approach.  LiDAR point cloud data are typically very large (millions
> to 100s of millions of points), contain attribute-like data such as
> echo intensity, and are somewhat spatially sequential.
> By spatially sequential, I mean that points near each other as they
> are stored in the sequential LAS file format are frequently near each
> other spatially (but not always).  Many coders take advantage of this
> property of the data by skipping data as they read it in -- naturally
> thinning the volume for a small accuracy penalty.  This is fine for
> visualization, but in a warehousing scenario, tossing out data is a
> big no-no.  But we also want a warehouse that can be (somewhat) fast,
> especially for spatial queries :)
> A first naive attempt to use the DiskStorageManager to store an index
> in parallel with a 32 million point (90mb) LAS file resulted in some
> disappointing results.  I used the default (70%) fill factor, 10 for
> the index and leaf capacity, and star for the rtree variant.  Nearly
> 4.5 hours of insertion later (I used a very small pagesize of 3, which
> is the reason for the slow insert, so I could get a feel for the
> minimum size required to make an index), the index of my 90mb, 32
> million point LAS file turned into 517mb of .idx + and 190mb of .dat
> file.  This isn't going to be practical.
> I need a plan B.  Anyone have any ideas how to tackle this problem in
> a way that balances space and time efficiency (though I'm not quite
> sure what defines "balance" in this instance) for insert and query?
> Should I start pursuing something like a KDB tree?  Should I figure
> out some sort of stripping/patching/tiling algorithm for the points to
> lessen the indexing load (this tends to be the standard approach to
> this problem)?  Work out a different StorageManager approach that is a
> clustered index of spatially clustered points?
> Howard
> PS sending to both lists because I hope to include spatial indexing
> functionality in libLAS if I can find a reasonable approach, and if
> any of the LiDAR folks have this one licked and would be willing to
> share, I'd be happy to take it.
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
More information about the Liblas-devel mailing list
