[Liblas-devel] readLas linking problem
Black, Michael (IS) Michael.Black2 at ngc.com
Mon Dec 21 08:51:38 EST 2009
I just found the thread that says you have to build your own debug versions of the library.
http://www.mail-archive.com/liblas-devel@lists.osgeo.org/msg00165.html
Interesting that I can build C debug programs though, but not C++ with the distributed binary libraries.  Seems to just be a linking problem.
I've been using liblas C interface in Code::Blocks -- so haven't played with the C++ interface at all until now.
Michael D. Black
Senior Scientist
Northrop Grumman Mission Systems
From: liblas-devel-bounces at lists.osgeo.org on behalf of Mateusz Loskot
Sent: Sat 12/19/2009 6:18 AM
To: cristovao_jdc at sapo.pt
Cc: liblas-devel at lists.osgeo.org
Subject: Re: [Liblas-devel] readLas linking problem
cristovao_jdc at sapo.pt pisze:
> Hi Mateusz, thanks for your help,
> I am using Microsoft Visual C++ 2008 Express Edition. I have already
>  done all of these steps:
> -add liblas.lib as a additional library dependence;
OK
> -add msvcr80.dll and msvcrp80.dll to the Visual C++ bin folder
What do you do it for?
It should not be necessary at all!
> Then I builded it, with the Visual C++ compiler(with no errors). But,
>  after that, when i tried to run it, i had a "Runtime Error R6034" -
> "An application has made an attempt to load de C runtime library
> incorrectly"
Do not manipulate any of C/C++ run-time libraries.
Do not copy msvcr*dll anywhere.
Rebuild, try to run again.
If still not working, get free program called Dependency Walker
(depends.exe, google will show you where it is available)
and open your test program exe with depends.exe program and check
if it reports any missing runtime libraries (DLL modules).
> I searched about this on the internet, and i found a connection with
> the "manifests", but i can't solve the problem.
There is no need to touch manifest and copy C/C++ runtime libraries
anywhere. If you build libLAS binary using NMAKE and makefile.vc files
or Visual C++ projects, everything should be set correctly.
p.s. Please, post your replies to liblas-devel mailing list too
so others have chance to track the discussion.
Best regards,
Mateusz Loskot
http://mateusz.loskot.net <http://mateusz.loskot.net/>
Liblas-devel mailing list
Liblas-devel at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/liblas-devel
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20091221/63e2df9d/attachment.html
More information about the Liblas-devel mailing list
