[Liblas-devel] Improved SRS support in liblas
Howard Butler hobu.inc at gmail.com
Wed Feb 4 10:29:08 EST 2009
On Feb 3, 2009, at 10:51 PM, Michael Rosen wrote:
> After discuss this offline with Howard, I'm posting this here for
> further discussion.
> A design limitation of liblas 1.0.0 is that we store the SRS
> information as a PROJ4 string.  This precludes the ability to
> reference non-proj4 data like the SRSName or the EPSG code.  An
> alternative might be to store this as a WKT string and use GDAL's
> global-but-not-exposed function "GTIFGetOGISDefn" to convert from
> the (libgeotiff) GTIFDefn structure to a WKT.  Similarly, I think
> GTIFSetFromOGISDefn (in libgeotiff) could reverse the operation.
> There appears to be no way to recover the EPSG code or "NAD83 /
> Washington North."  As it stands now, I think (but don't have a test
> case) that if we use liblas to read a file with this SRS and then
> write it out again, we can't keep the original SRS intact.
Michael,
This is a bug and a feature of libLAS :)  The original client needed
UTM Zone 15 support and the proj4 definition was expressive enough and
also kept us from having a GDAL dependency for libLAS.  On the windows
side this was important because of the hassle of setting GDAL_DATA,
etc, and because their most common use case was to be
manipulating .las files through ArcGIS Python GeoProcessing.  Putting
GDAL into that mix can cause a lot of trouble, especially because a
version of GDAL is already there, but we've no way to link against it
to use it.  Using proj4 strings made things simple, but as you clearly
describe, limited.
I would be more apt to pull the GTIFGetOGISDefn and GTIFGetOGISDefn
code from GDAL (renamed, obviously) and put it into libLAS.  It would
not eliminate the dependency on GDAL, but it would protect us from
GDAL changing anything and us depending on any non-standard linkage.
On Feb 4, 2009, at 12:33 AM, Hamish wrote:
> Hi,
> FWIW, WKT is no panacea. BUT you can embed the +proj string as a WKT
> extension, which may suit as a compromise.
> see
>  http://trac.osgeo.org/gdal/changeset/15681
> pages down? maybe Frank knows where they got to...
>  http://gdal.velocet.ca/~warmerda/wktproblems.html
>  http://home.gdal.org/warmerda/wktproblems.html
>  http://article.gmane.org/gmane.comp.gis.grass.devel/2971/
>  http://thread.gmane.org/gmane.comp.gis.grass.devel/30047
>  http://thread.gmane.org/gmane.comp.gis.grass.user/26612/focus=26615
> (these may be more OGR parser centric than GDAL/raster or PROJ.4)
And this is the other side of the problem, but I don't know that this
is libLAS' problem.  Proj.4 can be more expressive than WKT in many
instances, but the GeoTIFF keys are our limiting factor.
Additionally, I do know that GDAL doesn't support many of the vertical
datums descriptions that GeoTIFF keys have.  Maybe we should be
looking at something else entirely like CS-Map.  I'll go ask on their
list and see if it would be a fit for us.
Howard
More information about the Liblas-devel mailing list
