[Liblas-devel] libLAS / GRASS GIS workflow micro-tutorial for LIDAR data
Howard Butler hobu.inc at gmail.com
Fri Feb 6 12:00:02 EST 2009
On Feb 6, 2009, at 1:10 AM, Hamish wrote:
> Hi LIDAR users,
> I have written a mini-tutorial on using LAS formatted data with
> GRASS GIS. It is actually quite a simple task, but sometimes the
> incantations and programs to use are not so obvious if you haven't
> used the software extensively.
>  http://grass.osgeo.org/wiki/LIDAR#Micro-tutorial
> tested with GRASS 6.4rc2, libLAS 1.0.1, and LAS spec v1.0 data.
> improvements welcome. (directly to the wiki please)
Nice work Hamish.  Glad you are using libLAS.  When might GRASS
improve to using libLAS directly so there is no need for the las2txt
operations?
Also, libLAS and its linking libraries and include files are available
for OSGeo4W, which I see GRASS is starting to take advantage of for
its windows builds.
Howard
More information about the Liblas-devel mailing list
