[Liblas-devel] Improved SRS support in liblas
Michael Rosen mrosen at lizardtech.com
Fri Feb 6 16:16:47 EST 2009
> Proj.4 can be more expressive than WKT in many instances, but the GeoTIFF keys are our limiting factor.
If we store the SRS as a WKT can we, in principle, store all the GeoRef info in the LAS file?
> I do know that GDAL doesn't support many of the vertical datums descriptions that GeoTIFF keys have.
Are you sure?  Perhaps that was only true of older versions?
Here's the list of VCRS that geotiff supports: http://www.remotesensing.org/geotiff/spec/geotiff6.html#6.3.4.1
I think this is the VCRS that gdal 1.5.2 supports:  http://gdal.sourcearchive.com/documentation/1.5.2-2/epsg__vertcs_8inc-source.html
According to the Geotiff spec, there are no specific Vertical Datum codes currently defined.
msr
And this is the other side of the problem, but I don't know that this
is libLAS' problem.  Proj.4 can be more expressive than WKT in many
Additionally, I do know that GDAL doesn't support many of the vertical
datums descriptions that GeoTIFF keys have.  Maybe we should be
looking at something else entirely like CS-Map.  I'll go ask on their
list and see if it would be a fit for us.
Howard
Liblas-devel mailing list
Liblas-devel at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/liblas-devel
End of Liblas-devel Digest, Vol 14, Issue 2
More information about the Liblas-devel mailing list
