[Liblas-devel] LAS 1.2 and SRS improvements
Howard Butler hobu.inc at gmail.com
Wed Feb 18 13:35:15 EST 2009
On Feb 17, 2009, at 5:35 PM, Hamish wrote:
> Howard Butler wrote:
>> Debian has the luxury of using GDAL by default, which is the only
>> sane
>> way this should go. But I can't make GDAL a hard requirement for
>> libLAS.
> how about some sort of "SRS crippled" warning to the user if
> libgeotiff-
> only or without either of gdal/libgeotiff. (I expect the low-cal users
> don't want to see that over and over though :)
It's not so much crippled as "fully featured".  The GeoTIFF <-> WKT/
Proj4 processing of GDAL is much more developed than the simple key
translation that a latest libgeotiff has.  Neither is perfect, but for
those who can take the GDAL dependency, it might cause fewer headaches
in the end.
>> Another complication is likely to arise when GDAL in turn starts
>> linking against libLAS, but we'll burn that bridge when we need to :)
> we solved that circular dependency in GRASS by way of the gdal-
> plugin*.
> before that it was a complete nightmare for Debian to auto-build the
> packages. Both due to the order of compiling things**, and e.g. if a
> new
> grass package came out, GDAL had to be rebuilt, and so the many
> packages
> depending on GDAL had to be rebuilt, and so on, and so on.
> [*] http://download.osgeo.org/gdal/gdal-grass-1.4.3.tar.gz
>   see also http://packages.debian.org/lenny/libgdal1-1.5.0-grass
>   and the qgis-plugin-grass package (similar problem for QGIS<->GRASS)
> [**] the old method IIRC was to 1) build gdal without grass support,
> 2)
> build grass with gdal support, 3) remove & rebuild gdal with grass
> support.
> on 11+ hardware platforms.
Gee, that sounds awful.  Even more incentive to get this srs stuff out
into its own library.
More information about the Liblas-devel mailing list
