[Liblas-devel] Point limit in the software
    Neil Woodhouse
    Neil.Woodhouse at erdas.com
    Mon Feb 23 18:08:39 EST 2009
Howard,
	Thanks for your help. I assumed that the user data could be
exposed somehow in a viewer because it is a char I would thought it
simple to display. Decided to reuse the intensity for parameter display.
I will try out the code modification and will update you.
Neil
-----Original Message-----
Sent: Monday, February 23, 2009 5:55 PM
To: Neil Woodhouse
Cc: liblas-devel at lists.osgeo.org
Subject: Re: [Liblas-devel] Point limit in the software
On Feb 23, 2009, at 4:42 PM, Neil Woodhouse wrote:
> Howard,
> 	Some additional points. I am using the C API, so I don't think
> that the repair utility is available to me.
lasinfo's repair operations work by opening the LASWriterH in append
mode.  lasinfo.c uses the C API.  See the code in lasinfo.c for more
information
> Here some pseudo code to
> indicate my quandary.
> 	Create the header, point and writer
> 	For all blocks of data
> 		Process the data block
> 		Add the point to the LAS file
> 		Accumulate the bounds of the points
> 	Write the header
> 	Close the file
Can you try the following?:
	Create the header, point, and writer
		process
		add the point to the LASWriterH with _WritePoint
		accumulate the bounds of the points
	* Close the file with LASWriter_Destroy when you're done writing
your
points.
	* Open the file with LASReader_Create and fetch a copy of the
LASHeaderH then LASReader_Destroy
	* Set the extents and other items you wish to tweak on this
copy.
Don't mess with the point count, VLRs, or any other things that might
cause things to blow up
	* Open the file with LASWriter_Create in Append mode using your
header copy
	* Destroy the LASWriterH again with LASWriter_Destroy
> 	We are not using any VLR records, but do use the set user data
> function (LASPoint_SetUserData) for the point. I understand that
> this is
> an unsigned char.
UserData for 1.1 is a single unsigned char, right?  I will update my
test case to try this.
> BTW do you know of any free viewers that can view
> this?
View the user data?  I would assume that by definition, only the
application that created it would know how to interpret it.
> The reason for this workflow is that we do not know the number of
> points upfront and don't know the extents of them.
The LASWriter does not know the number of points it will write and
will do so with UpdateHeader for you as you destroy the writer with
LASWriter_Destroy or ~LASWriter when it goes out of scope.  As for the
extents, I think the only way to currently update them now is using
the pseudocode I described (it should be the same thing as what's
currently in lasinfo)
Hope this helps,
Howard
More information about the Liblas-devel
