Fwd: [Liblas-devel] txt2las - psid only 1 byte?
Howard Butler hobu.inc at gmail.com
Fri Jun 5 11:30:44 EDT 2009
oops, forgot to CC the list.
Begin forwarded message:
> From: Howard Butler <hobu.inc at gmail.com>
> Date: June 5, 2009 10:27:20 AM CDT
> To: Volker Wichmann <wichmann at laserdata.at>
> Subject: Re: [Liblas-devel] txt2las - psid only 1 byte?
> On Jun 5, 2009, at 4:48 AM, Volker Wichmann wrote:
>> Hi,
>> I have troubles converting an ASCII file with point source ids >
>> 254 to LAS 1.1 using the txt2las tool (version 1.2.0b3). It seems
>> to me, that the point source id is not written as unsigned short (2
>> bytes) but as unsigned char (1 byte) resulting psid=0. Is anybody
>> experiencing the same problem?
> I have filed a ticket on this item.  Please continue to track its
> development and improvement there (register for the site if you
> haven't already).  I have applied what I think is the fix to trunk
> if you have opportunity to build that.
> http://liblas.org/ticket/139
>> PS: I obtain correct results using the old lastools txt2las from
>> Martin Isenburg
> I so very wish I could make a convincing case to Martin to have him
> base his LAStools on libLAS.  I have tried very, very hard to do so,
> but I can't seem to make a compelling case.  It is unfortunate that
> we maintain essentially a fork of his utilities that have different
> capabilities than his.
More information about the Liblas-devel mailing list
