Fwd: [Liblas-devel] txt2las - psid only 1 byte?
Volker Wichmann wichmann at laserdata.at
Fri Jun 5 12:20:14 EDT 2009
Howard,
thanks for taking a look and applying a fix. I will report back next
week as soon as I have build a version from trunk.
Volker
Howard Butler wrote:
> oops, forgot to CC the list.
> Begin forwarded message:
>> From: Howard Butler <hobu.inc at gmail.com>
>> Date: June 5, 2009 10:27:20 AM CDT
>> To: Volker Wichmann <wichmann at laserdata.at>
>> Subject: Re: [Liblas-devel] txt2las - psid only 1 byte?
>> On Jun 5, 2009, at 4:48 AM, Volker Wichmann wrote:
>>> Hi,
>>> I have troubles converting an ASCII file with point source ids >
>>> 254 to LAS 1.1 using the txt2las tool (version 1.2.0b3). It seems
>>> to me, that the point source id is not written as unsigned short (2
>>> bytes) but as unsigned char (1 byte) resulting psid=0. Is anybody
>>> experiencing the same problem?
>> I have filed a ticket on this item.  Please continue to track its
>> development and improvement there (register for the site if you
>> haven't already).  I have applied what I think is the fix to trunk
>> if you have opportunity to build that.
>> http://liblas.org/ticket/139
>>> PS: I obtain correct results using the old lastools txt2las from
>>> Martin Isenburg
>> I so very wish I could make a convincing case to Martin to have him
>> base his LAStools on libLAS.  I have tried very, very hard to do so,
>> but I can't seem to make a compelling case.  It is unfortunate that
>> we maintain essentially a fork of his utilities that have different
>> capabilities than his.
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
More information about the Liblas-devel mailing list
