[Liblas-devel] txt2las - psid only 1 byte?
Volker Wichmann wichmann at laserdata.at
Mon Jun 8 11:31:03 EDT 2009
Howard Butler wrote:
>>> You will need to run ./autogen.sh as automake and libtoolize need to
>>> be rerun due to some new macros being implemented.
>>> Howard
>> Thanks, that worked. Also the psid seems to be written correctly now
>> - I just did a quick check with lasinfo. But I had to use an older
>> version of lasinfo to get it printed, it would be nice if the version
>> in trunk could be extended to print it again.
> hmm... do you think that lasinfo is interpreting it as a byte instead
> of a short?  Please add more details to that bug and I will look into it.
> Howard
it isn't printed at all - so this is more a feature request than a bug
report. Maybe it was just overlooked when the lasinfo output was changed
to use the --check flag.
Volker
More information about the Liblas-devel mailing list
