[Liblas-devel] txt2las - psid only 1 byte?
Howard Butler hobu.inc at gmail.com
Mon Jun 8 11:36:37 EDT 2009
On Jun 8, 2009, at 10:31 AM, Volker Wichmann wrote:
> Howard Butler wrote:
>>>> You will need to run ./autogen.sh as automake and libtoolize need
>>>> to be rerun due to some new macros being implemented.
>>>> Howard
>>> Thanks, that worked. Also the psid seems to be written correctly
>>> now - I just did a quick check with lasinfo. But I had to use an
>>> older version of lasinfo to get it printed, it would be nice if
>>> the version in trunk could be extended to print it again.
>> hmm... do you think that lasinfo is interpreting it as a byte
>> instead of a short?  Please add more details to that bug and I will
>> look into it.
>> Howard
> it isn't printed at all - so this is more a feature request than a
> bug report. Maybe it was just overlooked when the lasinfo output was
> changed to use the --check flag.
Ah, yes, it probably isn't printed or cumulated at all.  Please file a
bug for that in the Utilities component and I will try to get to it
for the 1.2.1 release.
More information about the Liblas-devel mailing list
