[Liblas-devel] liblas 1.0.1 on FreeBSD64 with gcc 3.4.4
Howard Butler hobu.inc at gmail.com
Thu Jun 18 23:46:00 EDT 2009
On May 27, 2009, at 9:34 PM, Howard Butler wrote:
> On May 27, 2009, at 9:10 PM, Jeff Hamann wrote:
>> $ ./configure --with-boost=no --with-gdal=/usr/home/hamannj/
>> gdal-1.6.0
> Is boost complaining?  Are you required to do --with-boost=no?  If
> so, I should fix that, boost is not a requirement to build the
> library at this time.
I have made an attempt to fix the issue of --with-boost=no being
required.  If you have an opportunity to test, it would be greatly
appreciated.
Howard
More information about the Liblas-devel mailing list
