[Liblas-devel] point source id
Volker Wichmann wichmann at laserdata.at
Mon Mar 30 14:14:29 EDT 2009
Thanks Howard, that's fine for me!
I really appreciate your efforts building libLAS,
best regards,
Volker
Howard Butler wrote:
> On Mar 30, 2009, at 12:07 PM, Mateusz Loskot wrote:
>> Volker Wichmann wrote:
>>> Hi,
>>> I've a question regarding the handling of the point source id:
>>> I just realized that neither txt2las nor las2txt support psid, the
>>> corresponding code seems to be commented out in trunk. Is there any
>>> reason for this?
>> What corresponding code you are referring to?
>> Recently, Point Source ID access has been implemented:
>> http://liblas.org/ticket/87
>> http://liblas.org/ticket/115
> It is commented out because the Point Source ID stuff didn't exist
> until 1.2, but it didn't make it into las2txt and txt2las for the 1.2
> release.
> I have fixed this issue in both trunk and the 1.2 branch
> http://liblas.org/ticket/121   If it is convenient for you to build
> from source, I would suggest  checking out a copy of the code from
> subversion http://liblas.org/svn/trunk
> Thanks for the report,
> Howard
More information about the Liblas-devel mailing list
