[Liblas-devel] Re: Converting LAS files to OGR (.shp)
Howard Butler hobu.inc at gmail.com
Thu Nov 26 21:02:15 EST 2009
las2ogr 1.2.1 is available from OSGeo4W.
http://trac.osgeo.org/osgeo4w/
Howard
On Nov 26, 2009, at 3:13 PM, Mateusz Loskot wrote:
> James Broadley wrote:
>> I'm a forest management tutor in New Zealand - we've just been given
>> some sample LiDAR data in LAS format - and I need to convert that to
>> OGR (vector) data in Shapefile format
>> I have no scripting experience at all - I have downloaded your
>> las2ogr.txt file - I have installed Python 2.6.4 & I imagine I would
>> need to put your example script into Python somehow ?
> las2ogr is not a script, it is a C++ program:
> http://liblas.org/browser/apps/las2ogr.cpp
> You've probably downloaded las2ogr.txt file which is a doc/manual:
> http://liblas.org/browser/doc/las2ogr.txt
> You will need to build libLAS with GDAL/OGR support, then you can
> build las2ogr.cpp program.
> If you provide me with some details about OS and compiler you have
> available, I could try to provide you with further instructions.
> ps. consider subscribing/sending to
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
> ps2. I added Howard Butler to CC, perhaps Howard could release las2ogr
> binaries for Windows packaged with OSGeo4W.
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> Charter Member of OSGeo, http://osgeo.org
More information about the Liblas-devel mailing list
