[Liblas-devel] invalid point(s)
M S mseibel at gmail.com
Thu Oct 1 14:05:15 EDT 2009
I had obtained the latest trunk I thought.  I will try this again.  My
apologies for time consumed as it appears to be my error.
Thanks,
Mark
On Thu, Oct 1, 2009 at 12:44 PM, Howard Butler <hobu.inc at gmail.com> wrote:
> On Sep 30, 2009, at 2:14 PM, M S wrote:
>> Great. Thanks!
>> It is "LID2006_86822.las.bz2".
> Mark,
> This file seems to work for me with the latest trunk
>> fire:data hobu$ las2las -i M_S_FL_Water_District-2.las --out foo.las
>> --eliminate_class 9
>> eliminated classification: 1269
>>  Reparing Bounding Box..
>> fire:data hobu$ lasinfo M_S_FL_Water_District-2.las -c|less
>>  Header Summary
>>  File Name: M_S_FL_Water_District-2.las
>>  Version:                    1.0
>>  Source ID:                  0
>>  Reserved:                   0
>>  Project ID/GUID:           '00000008-001e-07d1-0000-000000000000'
>>  System Identifier:         ''
>>  Generating Software:       'Merrick LiDAR Processing System'
>>  File Creation Day/Year:    264/2006
>>  Header Size                227
>>  Offset to Point Data       159735
>>  Number Var. Length Records 421
>>  Point Data Format          1
>>  Point Data Record Length   28
>>  Number of Point Records    3910005
>>  Number of Points by Return 3492884 396818 20056 247 0
>>  Scale Factor X Y Z         0.01 0.01 0.01
>>  Offset X Y Z               0.000000 0.000000 0.000000
>>  Min X Y Z                  605000.000000 1050000.010000 28.930000
>>  Max X Y Z                  610000.000000 1054999.980000 516.140000
>>  Spatial Reference
>> Geotiff_Information:
>>   Version: 1
>>   Key_Revision: 1.0
>>   Tagged_Information:
>>      End_Of_Tags.
>>   Keyed_Information:
>>      End_Of_Keys.
>>   End_Of_Geotiff.
>>  VLR Summary
>>   User: 'LASF_Projection' - Description: 'Projection Info'
>>   ID: 34736 Length: 40
>>   User: 'CloudPeakSoft' - Description: 'CPSInfo'
>>   ID: 0 Length: 128
>>   User: 'Merrick' - Description: 'Flight line record'
>>   ID: 101 Length: 342
>>   User: 'Merrick' - Description: 'Index to page of point records'
>>   ID: 102 Length: 64
>>   ID: 102 Length: 64
> A bunch of 'Index to page of point records' VLR entries
>>  Point Inspection Summary
>>  Header Point Count: 3910005
>>  Actual Point Count: 3910005
>>  Minimum and Maximum Attributes (min,max)
>>  Min X,Y,Z:            605000.000000,50.770000,28.930000
>>  Max X,Y,Z:            1050081.820000,1054999.980000,516.140000
>>  Bounding Box:         605000.00,50.77,1050081.82,1054999.98
>>  Time:                 137480.227189,488244.678279
>>  Return Number:        1,4
>>  Return Count:         1,4
>>  Flightline Edge:      0,0
>>  Intensity:            0,202
>>  Scan Direction Flag:  0,1
>>  Scan Angle Rank:      -20,17
>>  Classification:       1,10
>>  Point Source Id:      1,237
>>  Minimum Color:         0 0 0
>>  Maximum Color:         0 0 0
>>        (0) 3492884     (1) 396818      (2) 20056       (3) 247 (4) 0
>>  Total Points: 3910005
>>  Number of Returns by Pulse
>>        (1) 3091300     (2) 755362      (3) 62027       (4) 1316        (5)
>> 0   (6) 0   (7) 0
>>  Total Pulses: 3910005
>>  Point Classifications
>>         3762140 Unclassified (1)
>>           98090 Ground (2)
>>            1269 Water (9)
>>           48506 Reserved for ASPRS Definition (10)
More information about the Liblas-devel mailing list
