[Liblas-devel] c tutorial needed
Howard Butler hobu.inc at gmail.com
Wed Oct 28 12:29:51 EDT 2009
The best C API tutorials are the utilities, as they are almost all
written in C.
<http://liblas.org/browser/apps/las2las.c>
<http://liblas.org/browser/apps/lascommon.c>
These two probably provide the most coverage the C API. Otherwise the
place to look is the liblas.h header, which while it does not have any
examples, is very complete <http://liblas.org/doxygen/a00033.html>
HTH,
Howard
On Oct 28, 2009, at 11:06 AM, Riki Tiki wrote:
> hi,
> from liblas site i found the below c# code, can anyone show me the
> same example but written in c?
> also can you tell me which header files should be included in c
> programs trying to read and write las files? thanks!
> using System;
> using System.Text;
> using LibLAS;
> class Program
>   static void Main(string[] args)
>       try
>           LASReader lasreader = new LASReader(@"F:\sample_in.las");
>           LASPoint laspoint;
>           LASHeader lasheader = lasreader.GetHeader();
>           LASWriter laswriter = new LASWriter(@"F:\sample_out.las",
> lasheader, LASReadWriteMode.LASModeWrite);
>           Console.WriteLine("Number of points in file= {0}",
> lasheader.PointRecordsCount);
>           while (lasreader.GetNextPoint())
>               laspoint = lasreader.GetPoint();
>               //Console.WriteLine(laspoint.X + "," + laspoint.Y +
> "," + laspoint.Z);
>               laswriter.WritePoint(laspoint);
>       catch (LASException e)
>           Console.WriteLine("\nLASException! Msg: {0}", e.Message);
>       catch
>           Console.WriteLine("Unknown exception caught");
>       finally
>           Console.WriteLine("Do i need something to do?");
>       Console.WriteLine("End of file");
>       Console.Read();
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
More information about the Liblas-devel mailing list
