[Liblas-devel] compile errors
Volker Wichmann wichmann at laserdata.at
Tue Sep 8 05:45:27 EDT 2009
I've just checked out a recent version:
hg clone http://hg.liblas.org/main
Then
./autogen.sh and ./configure
result in a minimalistic configuration:
libLAS configuration summary:
   Version..................: 1.3.0
   Installation directory...: /usr/local
   C compiler...............: gcc -Wall -Wno-long-long -pedantic  -O3
-DNDEBUG
   C++ compiler.............: g++ -Wall -Wno-long-long -pedantic
-std=c++98  -O3 -DNDEBUG
   Debugging support........:
   GDAL support.............: no
   GeoTIFF SRS support......: no
   Spatial Index support....: no
   Oracle support...........: no
   zlib support.............: yes
    - lz....................: yes
    - INCLUDE directories...: -I/usr/include
   Boost support............: no
   LIBS.....................: -lz
   libLAS - http://liblas.org
But "make" results in the following error:
In file included from lasclassification.cpp:44:
../include/liblas/detail/utility.hpp:58:35: error:
boost/concept_check.hpp: No such file or directory
../include/liblas/detail/utility.hpp:76: error: ‘boost’ has not been
declared
../include/liblas/detail/utility.hpp: In function ‘void
liblas::detail::check_stream_state(std::basic_ios<_CharT, _Traits>&)
[with C = char, T = std::char_traits<char>]’:
../include/liblas/detail/utility.hpp:394:   instantiated from here
../include/liblas/detail/utility.hpp:362: error:
‘ignore_unused_variable_warning’ was not declared in this scope
make[2]: *** [lasclassification.lo] Error 1
make[2]: Leaving directory `/usr/local/src/liblas-hg/main/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/local/src/liblas-hg/main/src'
make: *** [all-recursive] Error 1
Any hints appreciated,
thanks,
Volker
More information about the Liblas-devel mailing list
