[Liblas-devel] invalid point(s)
M S mseibel at gmail.com
Tue Sep 29 16:27:21 EDT 2009
I noticed the timestamp number seems enormous?
the point attributes reported seem like reasonable elevation ranges,
but the section below that from --check they are out of wack?
I'm sure you guys, the experts, will quickly identify the problem.  I
just noticed that stuff upon trying to work with it.
Thanks to all.
Mark
On Tue, Sep 29, 2009 at 3:38 PM, Howard Butler <hobu.inc at gmail.com> wrote:
> On Sep 29, 2009, at 1:54 PM, Mateusz Loskot wrote:
>> M S wrote:
>>> The problem is for all the same .las files of a given provider.  It
>>> writes out odd elevations.  The one I can provide is the same problem
>>> for all it seems upon initial inspection.
>> It's impossible to tell what's wrong without data sample.
> http://liblas.org/ticket/142 might also be at fault.  Can we get a copy of a
> file for the http://liblas.org/sample sample library?  We'll do what it
> takes to make sure it works for you too ;)
> Howard
More information about the Liblas-devel mailing list
