[Liblas-devel] CMake working for current source?
Bellinski, Dan Dan.Bellinski at Woolpert.com
Wed Apr 7 09:19:26 EDT 2010
Hey Howard and or Mateusz,
I have been trying to compile the current source every so often for a
week or so and always get the output with errors:
Searching for GeoTIFF 1.2.5+ library
Trying OSGeo4W using default location OSGEO4W_ROOT=c:/OSGeo4W
Found GeoTIFF version: 1.2.5
Found GeoTIFF: C:/OSGeo4W/lib/geotiff_i.lib
Looking for ST_Create
Looking for ST_Create - found
Could NOT find TIFF (missing: TIFF_LIBRARY TIFF_INCLUDE_DIR)
Searching for GDAL 1.6.0+ library
NOTE: Required version is not checked - to be implemented
Found GDAL: C:/gdal-1.7.1/gdal_i.lib
Looking for OSRSetEquirectangular2
Looking for OSRSetEquirectangular2 - found
Enable libLAS utilities to build - done
Generating Visual Studio 10 user-specific settings in
lasinfo.vcproj.SAVIG-0123.SaVig 0123.user
lasmerge.vcproj.SAVIG-0123.SaVig 0123.user
las2las.vcproj.SAVIG-0123.SaVig 0123.user
las2txt.vcproj.SAVIG-0123.SaVig 0123.user
txt2las.vcproj.SAVIG-0123.SaVig 0123.user
las2ogr.vcproj.SAVIG-0123.SaVig 0123.user
CMake Error at C:/Program Files/CMake
2.8/share/cmake-2.8/Modules/CPack.cmake:762 (message):
CPack package description file: "README.txt" could not be found.
Call Stack (most recent call first):
C:/Program Files/CMake 2.8/share/cmake-2.8/Modules/CPack.cmake:766
(cpack_check_file_exists)
CMakeLists.txt:309 (INCLUDE)
CPack readme resource file: "README.txt" could not be found.
C:/Program Files/CMake 2.8/share/cmake-2.8/Modules/CPack.cmake:768
CMake Error: The following variables are used in this project, but they
are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the
CMake files:
TIFF_LIBRARY (ADVANCED)
linked by target "las_c" in directory C:/liblas/src
linked by target "las2ogr" in directory C:/liblas/apps
Configuring incomplete, errors occurred!
Is the build working for you or is it still a WIP? I am running it
through the CMake 2.8.1 gui. Also I know I have libtiff (with source
too) installed from OSGeo4w but it can't find it. I was having the same
problem when using my own gdal/libgeotiff/libtiff all compiled from
source.
Thanks!
Dan
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20100407/6cc22ceb/attachment.html
More information about the Liblas-devel mailing list
