[Liblas-devel] CMake working for current source?
Dan Bellinski Dan.Bellinski at Woolpert.com
Wed Apr 7 10:59:23 EDT 2010
Thanks a lot for the quick reply Howard. I also appreciate all the help you
have been giving me throughout the whole compilation process!
Setting the view to Advanced allowed me to locate my TIFF library and
include directories so that error is gone!
The fix you mentioned seems to be working
(http://hg.liblas.org/main/file/1156369845c1/CMakeLists.txt#l73); my
c:\liblas (base) directory has the original README file + README.txt which
was automatically created when running cMake... but the CPack error in cMake
is still there! (CPack readme resource file: "README.txt" could not be
found). Is possibly using the wrong README file? Like I said, the readme
file it is renaming is from the base liblas directory (the 11KB one).
Thanks,
Dan
Howard Butler wrote:
> On Apr 7, 2010, at 8:19 AM, Bellinski, Dan wrote:
>> Hey Howard and or Mateusz,
>> I have been trying to compile the current source every so often for a
>> week or so and always get the output with errors:
>> Searching for GeoTIFF 1.2.5+ library
>> Trying OSGeo4W using default location OSGEO4W_ROOT=c:/OSGeo4W
>> Found GeoTIFF version: 1.2.5
>> Found GeoTIFF: C:/OSGeo4W/lib/geotiff_i.lib
>> Looking for ST_Create
>> Looking for ST_Create - found
>> Could NOT find TIFF (missing: TIFF_LIBRARY TIFF_INCLUDE_DIR)
>> Searching for GDAL 1.6.0+ library
>> NOTE: Required version is not checked - to be implemented
>> Found GDAL: C:/gdal-1.7.1/gdal_i.lib
>> Looking for OSRSetEquirectangular2
>> Looking for OSRSetEquirectangular2 - found
>> Enable libLAS utilities to build - done
>> Generating Visual Studio 10 user-specific settings in
>> lasinfo.vcproj.SAVIG-0123.SaVig 0123.user
>> lasmerge.vcproj.SAVIG-0123.SaVig 0123.user
>> las2las.vcproj.SAVIG-0123.SaVig 0123.user
>> las2txt.vcproj.SAVIG-0123.SaVig 0123.user
>> txt2las.vcproj.SAVIG-0123.SaVig 0123.user
>> las2ogr.vcproj.SAVIG-0123.SaVig 0123.user
>> CMake Error at C:/Program Files/CMake
>> 2.8/share/cmake-2.8/Modules/CPack.cmake:762 (message):
>> CPack package description file: "README.txt" could not be found.
>> Call Stack (most recent call first):
>> C:/Program Files/CMake 2.8/share/cmake-2.8/Modules/CPack.cmake:766
>> (cpack_check_file_exists)
>> CMakeLists.txt:309 (INCLUDE)
>> CPack readme resource file: "README.txt" could not be found.
>> C:/Program Files/CMake 2.8/share/cmake-2.8/Modules/CPack.cmake:768
>> CMake Error: The following variables are used in this project, but they
>> are set to NOTFOUND.
>> Please set them or make sure they are set and tested correctly in the
>> CMake files:
>> TIFF_LIBRARY (ADVANCED)
>> linked by target "las_c" in directory C:/liblas/src
>> linked by target "las2ogr" in directory C:/liblas/apps
>> Configuring incomplete, errors occurred!
>> Is the build working for you or is it still a WIP? I am running it
>> through the CMake 2.8.1 gui. Also I know I have libtiff (with source too)
>> installed from OSGeo4w but it can’t find it. I was having the same
>> problem when using my own gdal/libgeotiff/libtiff all compiled from
>> source.
> The README.txt thing is due to the fact that CPack, CMake's packaging
> framework, will not accept a file named README -- it must have an
> extension.  There is a command called file() that tries to copy the README
> file to README.txt to satisfy this
> (http://hg.liblas.org/main/file/1156369845c1/CMakeLists.txt#l73).  It is
> working locally on my 2.8.1 machine on osx, maybe this doesn't work on
> windows...  If you manually copy README to README.txt in the same
> directory, you should get around this
> I also have tried to clear the advanced marking of TIFF_LIBRARY
> (http://hg.liblas.org/main/file/1156369845c1/CMakeLists.txt#l164) to
> easily allow the user to override it, but it seems this isn't working...
> Mat?  If you click the "Simple View" dropdown in the GUI and change to
> "Advanced View", you should be able to manually set the location of
> TIFF_LIBRARY
> Howard
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
View this message in context: http://n3.nabble.com/Liblas-devel-CMake-working-for-current-source-tp702989p703162.html
Sent from the libLAS Developers mailing list archive at Nabble.com.
More information about the Liblas-devel mailing list
