[Liblas-devel] Re: las 1.0 point data record format (jasim)
Aaron Reyna aaron.reyna at gmail.com
Thu Aug 12 12:19:25 EDT 2010
If I understand you correctly, all of that information is stored in the las
header, which you can easily read by pulling that info out through whichever
API you choose. Another easy way to get that info is to use the LAStools
lasInfo tool from the terminal on the specific las file in question.
http://trac.liblas.org/raw-attachment/wiki/WikiStart/ASPRS-Workshop-NOAA-Demo.pdf
I found this link very helpful when i was starting out, especially page 10.
Good Luck!
aaron
>   1. las 1.0 point data record format (jasim)
Probably I am missing something, if anyone could help me?
> My question is: so I read Point data in format 0, then how do I know
> whether the point data is in format 0 or 1? If anyone could
> clearly point to the result, I would be happy!
> Thanks!
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
> End of Liblas-devel Digest, Vol 32, Issue 1
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20100812/698ae7d2/attachment.html
More information about the Liblas-devel mailing list
