[Liblas-devel] Re: las 1.0 point data record format (jasim)
jasim jasim at mail.kz
Thu Aug 12 13:37:48 EDT 2010
On Thu, 12 Aug 2010 09:19:25 -0700
  Aaron Reyna <aaron.reyna at gmail.com> wrote:
> If I understand you correctly, all of that information is stored in
>the las
> header, which you can easily read by pulling that info out through
>whichever
> API you choose. Another easy way to get that info is to use the
>LAStools
> lasInfo tool from the terminal on the specific las file in question.
> http://trac.liblas.org/raw-attachment/wiki/WikiStart/ASPRS-Workshop-NOAA-Demo.pdf
> I found this link very helpful when i was starting out, especially
>page 10.
> Good Luck!
> aaron
>>   1. las 1.0 point data record format (jasim)
> Probably I am missing something, if anyone could help me?
>> My question is: so I read Point data in format 0, then how do I know
>> whether the point data is in format 0 or 1? If anyone could
>> clearly point to the result, I would be happy!
>> Thanks!
>> Liblas-devel mailing list
>> Liblas-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/liblas-devel
>> End of Liblas-devel Digest, Vol 32, Issue 1
Hi Aaron,
Thanks a lot for pointing that... Shame on me for not carefully
reading that part... :)
I feel embarrassed now!!!
Thanks!!!
More information about the Liblas-devel mailing list
