[Liblas-devel] liblas fails to compile
Tommy Stehle TStehle at HNTB.com
Tue Aug 24 11:42:00 EDT 2010
The only program options files that I have are:
/usr/local/lib/libboost_program_options.a
/usr/local/lib/libboost_program_options.so
/usr/local/lib/libboost_program_options.so.1.44.0
Tommy
-----Original Message-----
Sent: Tuesday, August 24, 2010 9:17 AM
To: Tommy Stehle
Cc: liblas-devel at lists.osgeo.org
Subject: Re: [Liblas-devel] liblas fails to compile
On Aug 23, 2010, at 4:12 PM, Howard Butler wrote:
> On Aug 23, 2010, at 4:01 PM, Tommy Stehle wrote:
>> The results are attached from the verbose compile...
>> cd /home/tstehle/liblas/main/apps && /usr/bin/cmake -E cmake_link_script
>> CMakeFiles/las2las2.dir/link.txt --verbose=1 /usr/bin/c++ -fPIC -Wall
>> -Wno-long-long -ansi -std=c++98 CMakeFiles/las2las2.dir/las2las2.cpp.o
>> CMakeFiles/las2las2.dir/laskernel.cpp.o -o ../bin/las2las2 -rdynamic
>> -L/usr/lib/oracle/11.2/client64/lib ../bin/liblas.a /usr/local/lib/libtiff.so
>> /usr/local/lib/libgeotiff.so /usr/local/lib/libgdal.so
>> /usr/lib/oracle/11.2/client64/lib/libclntsh.so
>> /usr/lib/oracle/11.2/client64/lib/libocci.so -lnnz11
>> -lboost_program_options-mt
Do you have "libboost_program_options-mt" in your /usr/local/lib directory instead of "boost_program_options-mt"?
This e-mail and any files transmitted with it are confidential
and are intended solely for the use of the individual or entity
to whom they are addressed.
If you are NOT the intended recipient or the person responsible for
delivering the e-mail to the intended recipient,
be advised that you have received this e-mail in error and that any use,
dissemination, forwarding, printing or copying this e-mail is strictly prohibited.
More information about the Liblas-devel mailing list
