[Liblas-devel] #pragma once
Howard Butler hobu.inc at gmail.com
Fri Feb 12 22:17:54 EST 2010
Upon further reflection, I'm going to drop this idea for now.  I mostly wanted #pragma once to attempt to clean up some of the verbosity and boilerplate of the header files, but there are use cases where someone might want to be able to tell if a header has been included or not, and the include guards are the way to do that.  #pragma once will never support such a thing.
Thanks for the feedback,
Howard
On Feb 8, 2010, at 10:52 AM, Black, Michael (IS) wrote:
> Just one objection -- it's not "standard".
> http://google-styleguide.googlecode.com/svn/trunk/cppguide.xml?showone=Windows_Code#Windows_Code
> If you intend to restrict your code to only compatible compilers, then fine.  The other recommendations I saw said to use both #ifdef and #pragma once -- then you get both.  But if maximum portability is not your concern.....
> Looks like it's still in the throws of being implemented -- and without it being a standard it seems risky...
>  http://software.intel.com/en-us/articles/cdiag1782/
> If it ain't broke -- don't fix it...
> Michael D. Black
> Senior Scientist
> Northrop Grumman Mission Systems
> From: liblas-devel-bounces at lists.osgeo.org on behalf of Howard Butler
> Sent: Mon 2/8/2010 9:06 AM
> To: Liblas-devel at lists.osgeo.org
> Subject: [Liblas-devel] #pragma once
> All,
> I would like to remove our #ifdef-style include guards in all of our .hpp and .h files and instead use the "#pragma once" [1] compiler directive.  I can't think of any compilers that people are using with libLAS that do not support this directive, and it will cut down on a lot of the boilerplate that exists in the headers.
> Any objections?
> Howard
> [1] http://en.wikipedia.org/wiki/Pragma_once_______________________________________________
> Liblas-devel mailing list
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
More information about the Liblas-devel mailing list
